| Later model transmission mount in 65 Valiant https://mail.slantsix.org/forum/viewtopic.php?t=68036 |
| Author: | Rick Covalt [ Sun Dec 22, 2024 12:37 pm ] |
| Post subject: | Later model transmission mount in 65 Valiant |
When I do swap my 4 speed back into the car I was considering installing the later through bolt style of rear transmission mount in the car. I didn't know it if the later cross member is a bolt in or if I would just need to modify an early one to accept the later mount. The later capture mount just looks a lot more robust to me. So is this worth doing or should I just run what I got. |
| Author: | Greg Ondayko [ Sun Dec 22, 2024 1:14 pm ] |
| Post subject: | Re: Later model transmission mount in 65 Valiant |
If you get a poly version of what you have it will be fine. I have that mount in the Ruster with transbrake and I had it in the '69 Dart with slicks and 3400# car - Never gave me problems If you want to swap to the spool mount, then I believe you will have to mate the spool to a new transmission member. I am not certain on this however. Good Luck! Greg |
| Author: | Rick Covalt [ Sun Dec 22, 2024 3:47 pm ] |
Every time I look at the single small bolt at the base of that mount I ask myself why. There is no reason it could not have had two bolts there or at least a larger single one. Thanks Greg! |
| Author: | SlantSixDan [ Sun Dec 22, 2024 4:41 pm ] |
Greg's right. Assuming a good-quality part, even the rubber version of the stock pre-'73 vertical-shear trans mount is quite durable. They go for decades. Best spend effort-money-time elsewhere. |
| Author: | Rick Covalt [ Sun Dec 22, 2024 4:50 pm ] |
Quote: Best spend effort-money-time elsewhere.
Possibly, But I won't be driving it like grandma's 100HP grocery getter either. |
| Author: | slantzilla [ Sun Dec 22, 2024 6:38 pm ] |
IIRC, the later spool mount crossmember will need some tweaks to make it work. Should be child's play for you. |
| Author: | Greg Ondayko [ Mon Dec 23, 2024 4:18 am ] |
There is a 2 bolt version of that block mount too. Greg |
| Author: | Dart270 [ Tue Dec 24, 2024 5:04 am ] |
I'm a futzing nerd... Lou |
| Author: | Greg Ondayko [ Tue Dec 24, 2024 7:25 am ] |
Lou Yessir you are! |
| Author: | Rick Covalt [ Tue Dec 24, 2024 9:02 am ] |
I am pretty sure I am not smart enough to be a nerd, but I am a tinkerer! |
| Author: | Greg Ondayko [ Fri Dec 27, 2024 4:23 pm ] |
Apparently I cannot type or spell. You know that it is not AI generated. |
