Early vs. later A body motor mount brackets
https://mail.slantsix.org/forum/viewtopic.php?t=68125
Page 1 of 2
Author:  Bsa6364 [ Wed Mar 12, 2025 11:15 pm ]
Post subject:  Early vs. later A body motor mount brackets
I will be putting a post ‘67 225 slant and and a ‘72 model 904 (the sliding yoke style) in my ‘64 Barracuda (originally a V8 car). Will ‘67-‘72 style A body (or another body for that matter) motor mount brackets fit in this combination? I read somewhere that doing so technically fits but, on a manual transmission, it pushes the engine or bell housing into the Z bar and causes clutch action problems. Will doing this in an automatic car push the transmission back too far as to touch the firewall/transmission tunnel or interfere with the fit or travel of the driveshaft and/or yoke? Thanks!
Author:  slantzilla [ Thu Mar 13, 2025 8:45 am ]
Post subject:  Re: Early vs. later A body motor mount brackets
If my memory serves me correctly, they are very different, especially the passenger side.
Author:  SlantSixDan [ Thu Mar 13, 2025 5:49 pm ]
You need a pair of '62-'66 Slant-6 motor mount brackets for this install.
Author:  Bsa6364 [ Thu Mar 13, 2025 6:24 pm ]
Thanks for the info. Nothing worse than buying a set of the wrong brackets “on a hunch” that won’t fit and will sit in my shop for the next decade! Happy to avoid it … for once!
Author:  Charrlie_S [ Fri Mar 14, 2025 4:27 am ]
You will also need to use the early (66 down) oil pan and pick up tube.
Author:  mcnoople [ Fri Mar 14, 2025 9:36 am ]
Is the pan necessary on a car that has the V8 center link. My memory is that sumps are in the same place but the less girthy on the early engine, but this is a 30 year since last dealing with it memory.
Author:  SlantSixDan [ Fri Mar 14, 2025 2:44 pm ]
No, the sumps are located differently. You will need the '60-'66 pan and pickup.
Also a set of '62-'66 motor mounts. Crummy compressed-cow-poo items from the parts store or the good ones from Polybushings (have a conversation with Johnny @ Polybushings if you want a softer-than-he-usually-makes set of them).
Author:  Charrlie_S [ Fri Mar 14, 2025 2:48 pm ]
pics of pans. https://www.slantsix.org/forum/viewtopic.php?t=3337
Author:  Rick Covalt [ Fri Mar 14, 2025 5:39 pm ]
You can also notch the K-frame on the RH side and then use the "center" sump pan ( Blue one in the picture) off the later engine . Of course you need to reinforce the area you cut. Early pans are not on every corner anymore. :D
Author:  slantzilla [ Sat Mar 15, 2025 5:08 am ]
I have 2 laying around. :mrgreen:
Author:  kesteb [ Sun Mar 16, 2025 10:35 am ]
A F-Body oil pan and pickup along with the '64 - '66 V8 center link will work. The oil pan needs to be notched on the driver side front corner for clearance. Much easier the notching the K-member.
Author:  Bsa6364 [ Sun Mar 16, 2025 10:12 pm ]
‘62-‘66 mounts? If you want to sell a set, let me know?
Author:  Bsa6364 [ Sun Mar 16, 2025 10:20 pm ]
If by saying “notched on the driver side front corner for clearance” you mean give it a few whacks with a hammer, that sounds preferable to me than cutting on the K member. Honestly, if you mean cut a section out of the pan and weld in a flat piece of metal in it’s place to gain clearance that also sounds preferable to cutting the K … just more effort.
I have been eyeballing an engine out of a truck (year unknown; originality of engine to this truck unknown), so I have no idea what oil pan is on it.
Author:  slantzilla [ Mon Mar 17, 2025 10:45 am ]
Oil pans.
If I spent a day digging around at my shop I might have the mounts, but might never find them.
Author:  Bsa6364 [ Mon Mar 17, 2025 3:32 pm ]
Oil pans.
If you happen onto one that you want to sell, it me know. No rush.
Page 1 of 2 All times are UTC-08:00
