It is currently Mon Nov 17, 2025 2:32 am
 Post subject: Rear main seal
PostPosted: Thu Apr 10, 2025 5:28 am
Car Model: D100 custom
New member.i apologize in advan.unfamiliar with how to navigate and/or post. Couldn't find a thread about rear main crank seal so I saw new post .
If anyone can help I sure would b grateful. Have 1985d100 custom 2w.d. auto. Can not find the 2piece crank seal anywhere the dealership gave me a part number no help online there are ones for d150 V6 or V8 etc. Called everywhere searching online for days. Napa has one listed for w100 suggesting it's the same. I don't want to assume anything while lying on the ground w transmission on my motorcycle jack. Pls help
 Post subject: Re: Rear main seal
PostPosted: Thu Apr 10, 2025 5:48 am
Car Model: 78 aspen
quick search from the shop gets this from o'rielly auto part...
Precision Multi-Purpose Oil Seal PSO 5414
PostPosted: Thu Apr 10, 2025 7:09 am
Oops
PostPosted: Thu Apr 10, 2025 7:12 am
I just got an email from rock auto as I've bought parts for my 85 truck from there, with a heads up to "clearance" parts, and one of the things that was included in their list of parts on clearance was a /6 rear main seal.... I don't need one right now, actually have an extra or 2 already.
Once you buy from them they occasionally send you notices of parts they have on clearance vehicles that you have bought stuff from them for, in the past.
PostPosted: Thu Apr 10, 2025 7:14 am
Never actually heard of that brand of any kind of engine gasket or seal
PostPosted: Thu Apr 10, 2025 7:38 am
Car Model: 78 aspen
same as the ujoint/suspension parts. parent company looks to be ozark automotives(from the copyright of the ujoint catalog)
PostPosted: Thu Apr 10, 2025 8:03 am
Car Model: 78 aspen
and yes the 4wheel drive one will be the same. the motor parts don't change from 2wd to 4wd
PostPosted: Thu Apr 10, 2025 10:44 am
If you want one that's easier to make not-leak, there's this (which, yes, also fits big block V8s). Like any oil seal, it has to be installed rightside-in. I'd put the installation split at 12:00 with a small dab of RTV.
PostPosted: Thu Apr 10, 2025 11:18 am
Cool item, Dan. Yes, you can use the BB Mopar part number/seal too.
PostPosted: Thu Apr 10, 2025 12:30 pm
I like it.
Thanks for the info.
PostPosted: Thu Apr 10, 2025 2:16 pm
Car Model: 1966 Dodge Dart
Also, if you're wondering how to remove an original rope seal without removing the crank: Use one of these.
Matt Cramer
PostPosted: Thu Apr 10, 2025 3:14 pm
The last few seals I purchased, came with the "Main" seal and the side seals for both the slant six, and the big block in the same package.
Anyone need some extra big block side seals? :)
PostPosted: Thu Apr 10, 2025 3:48 pm
I have also used drywall screws for my version of the sneaky pete tool for just a few cents.
Worked fine on my 318's
Users browsing this forum: Google [Bot] and 19 guests
