| WANTED!!!! '68-'69 Slant Six 170ci engine https://mail.slantsix.org/forum/viewtopic.php?t=68388 |
| Author: | Fiakus [ Sun Oct 12, 2025 4:43 pm ] |
| Post subject: | WANTED!!!! '68-'69 Slant Six 170ci engine |
GREETINGS ALL!!! I stumbled across this forum quite a few years ago when I started really gain an interest in engines, especially inline 6s, then specifically the Slant Six. Like any gearhead(real or imagined Premise: 170ci LG block ('68-'69) Bored over 0.050" Upgraded Camshaft Lightweight Pistons Ported Head 198 Forged Crankshaft Fuel Injection Individual Throttle Bodies Supercharger Dutra Duals Exhaust Manifold Scratch your heads and go ahead and ask all the "Why?!" questions. My reply will be "Why not. Many Thanks, Fiakus |
| Author: | Dart270 [ Mon Oct 13, 2025 5:31 am ] |
| Post subject: | Re: WANTED!!!! '68-'75 Slant Six 170ci |
Sounds like a fun project. Here are a few questions: 1) What kind of car will you put this into? 2) What is your budget for engine, EFI, boost, and transmission? From what you have written, you should plan on at least $10,000 for a rebuilt engine including EFI system and supercharger. Probably more like $12,000-15,000 if you want all new parts. 3) In case you do not know this, you should be looking for a crank from a 198 Slant 6 to put into your 170 block. You should put some specifically written posts in the "Parts Wanted" section to ask for the block and crank. 170s were made 1960-1969 (or 1968?) and 198s were made 1969-1974, IIRC. Lou |
| Author: | Fiakus [ Mon Oct 13, 2025 8:41 am ] |
Lou, Thanks for the questions and input. Question 1) What kind of car am I putting this engine in… no clue yet. Question 2) Budget? I’m definitely aware that what I want to build is budget intensive however I am looking at this as a long term project to enjoy over time. I had never considered attempting an engine build before a few years ago, but I realized my skills I’vedeveloped over 30+ years as an industrial maintenance technician do translate. :p So I finally decided to gird my loins and do it. Thanks for the clarification on the 170 year models. I pulled the data originally from a chart from here in the forum. In my haste to make this post I read the chart wrong. :p Attachment:
I’ll be sure to correct my original post. I did know I will need the 198 forged crank for this but I was hoping to find the 170 with the matching crank because I actually have 3 variants of this 170 built I want to try but the stroker with the super charger is where I want to start. I have searched online for 170s but they seem quite allusive. But I do know I want the ‘68-‘69 castings because they are reported to be the better ones to use. Thanks Again, Erik Z. |
| Author: | Charrlie_S [ Tue Oct 14, 2025 7:24 am ] |
| Post subject: | Re: WANTED!!!! '68-'69 Slant Six 170ci engine |
I personally doubt the 68-69 170 engines are any better than the early ones. As far as I know there are no differences in the 68-69 170 engine from the 67 down except for the crank shaft (larger converter pocket).. Unlike the 225 engine that went from 3 freeze plugs to 5 freeze plugs (possibly othe mads as well) the 170 kept 3 freeze plugs untill the end. PS: I might be able to help you witha 170. Will need to look at what I have. Send me a PM and I will give you my phone number. |
| Author: | SlantSixDan [ Tue Oct 14, 2025 1:51 pm ] |
Quote: 170s were made 1960-1969 (or 1968?) and 198s were made 1969-1974, IIRC.
170s were made from '60 to '70something, though only for export outside of the US/Canada market after the '69 model year. I mention this because a bunch of years ago there was someone selling off a stash of NOS (in crates) '70-'71-'72 170 short blocks.198s were '70-'74. US/Canada only, as far as I know. |
| Author: | hyper_pak [ Fri Oct 17, 2025 5:22 am ] |
Eric Z, hello from the DFW! I have a 170 crank you can get. I also have a 198 crank. Send me a Personal Message if you want to contact me and talk slant stuff. I assume you are down near Houston? Maybe Tyler? Stan |
| Author: | 72polara [ Sat Oct 25, 2025 12:22 pm ] |
I have a complete 170 engine, but it's from 1962 i believe, if you're interested. I can strip it to just the block if that's all you're interested in. |
| Author: | Dart270 [ Sun Oct 26, 2025 5:18 am ] |
I just discovered I have a spare 170 crank. You'll have to arrange transport from VA, though. Lou |
