It is currently Wed Nov 19, 2025 10:25 pm
 Post subject: Windows not cooperating
PostPosted: Wed Oct 01, 2003 9:14 pm
The windows on my 63 seem to really stick in place when it's wet out. Is there a lubricant that I can apply to the old track rubber to make them roll up and down nicely?
thanks
Joe
My 63 Valiant
http://www.readersrides.com/rides/class ... aliant.htm
<img src="http://www.readersrides.com/slant6-02.gif"/>
PostPosted: Wed Oct 01, 2003 10:26 pm
Keep em wet with armoral? It'll nourish the rubber and leave it soft.
PostPosted: Thu Oct 02, 2003 11:19 am
Armourall is the key, but you may still experience sticking as I did due to hardened factory grease on the crank assembly. If you have to pull the panel, make notes and take polaroids before you disassemble anything to aid you in putting it back correctly--next time i'll get lazy and convert to power while i'm in there...Dave
