It is currently Tue Nov 18, 2025 7:15 pm
 Post subject: 73' Dart Project
PostPosted: Tue Nov 04, 2003 12:15 pm
FYI to anyone considering a suspension rebuild, I just completed this on my 73' Dart, following the methods in Tom Condron's book and I must say it worked out well. Using all Moog parts, including the offset upper control arm bushings installed the Condron way, and 11/16 tie rod ends, the car sure handles drives and rides much better. With the UCA bushings installed this way the alignment shop was able to get 3.5 degrees + caster (and the other specs recommended by Condron) which has much to do I think with a new feeling of stable tracking, especially at speed. My project also included the 340 t-bars and conversion from drum to disc brakes. In addition to the Condron book, this forum was a great help to me as I worked my way through several snags to project completion. I still have more to do such as a 7.25 to 8.25 rear end swap in the works, and this spring installing an 833 OD, but I just thought I'd share what's done so far. Thanks to all Slantsix.org contributors.
PS- To anyone planning this kind of project I strongly recommend buying a donor car, which I did for little $, and the value of the parts yield from the donor far exceeded its cost.
PostPosted: Tue Nov 04, 2003 1:06 pm
Yes, a complete donor car is the best way to go, $60 for a crapped out '75 Dart saved me the hundreds of dollars it would have costed to individually buy all of the parts seperately. And what I couldn't use, I was able to resell and recoop the original investment.
PostPosted: Tue Nov 04, 2003 2:35 pm
I have recently read this Condron book, and I can also heartily recommend that to someone starting a project like this.
PostPosted: Tue Nov 04, 2003 3:01 pm
Do you have a link, etc for finding this book? I want to add it to my library.
PostPosted: Tue Nov 04, 2003 5:28 pm
The last address I had was:
Acme Mail Order
PO Box 282612
San Francisco, CA 94128-2612
Drop him a note for pricing.
He may have some info posted on the Moparalley.org website.
http://www.moparalley.org
Users browsing this forum: Bing [Bot] and 8 guests
