| 73' Dart Project https://mail.slantsix.org/forum/viewtopic.php?t=7437 |
| Author: | SBNEWC33 [ Tue Nov 04, 2003 12:15 pm ] |
| Post subject: | 73' Dart Project |
FYI to anyone considering a suspension rebuild, I just completed this on my 73' Dart, following the methods in Tom Condron's book and I must say it worked out well. Using all Moog parts, including the offset upper control arm bushings installed the Condron way, and 11/16 tie rod ends, the car sure handles drives and rides much better. With the UCA bushings installed this way the alignment shop was able to get 3.5 degrees + caster (and the other specs recommended by Condron) which has much to do I think with a new feeling of stable tracking, especially at speed. My project also included the 340 t-bars and conversion from drum to disc brakes. In addition to the Condron book, this forum was a great help to me as I worked my way through several snags to project completion. I still have more to do such as a 7.25 to 8.25 rear end swap in the works, and this spring installing an 833 OD, but I just thought I'd share what's done so far. Thanks to all Slantsix.org contributors. PS- To anyone planning this kind of project I strongly recommend buying a donor car, which I did for little $, and the value of the parts yield from the donor far exceeded its cost. |
| Author: | kesteb [ Tue Nov 04, 2003 1:06 pm ] |
Yes, a complete donor car is the best way to go, $60 for a crapped out '75 Dart saved me the hundreds of dollars it would have costed to individually buy all of the parts seperately. And what I couldn't use, I was able to resell and recoop the original investment. |
| Author: | Dart270 [ Tue Nov 04, 2003 2:35 pm ] |
I have recently read this Condron book, and I can also heartily recommend that to someone starting a project like this. Lou |
| Author: | Rob Simmons [ Tue Nov 04, 2003 3:01 pm ] |
Do you have a link, etc for finding this book? I want to add it to my library. |
| Author: | Doctor Dodge [ Tue Nov 04, 2003 5:28 pm ] |
The last address I had was: Acme Mail Order PO Box 282612 San Francisco, CA 94128-2612 Drop him a note for pricing. He may have some info posted on the Moparalley.org website. http://www.moparalley.org DD |
