It is currently Wed Nov 19, 2025 2:30 am
 Post subject: lightened dipstick
PostPosted: Mon Oct 28, 2002 9:02 am
OK, this is weird. but my 73 Dart (225 slant 6) has a dipstick that looks as if the end has been chewed off _ all the marks are missing. the socket is loose in the block, so the stick could move around...anybody else ever heard of this/have it happen?
jfalcone@easystreet.com
 Post subject: Sounds like a rod knock
PostPosted: Mon Oct 28, 2002 7:16 pm
When I fired up my good motor, I heard a rattle coming from the bottom end. I noticed the top of the dipstick wiggling and pulled it out. Noise went away. I had to bend the stick a little to keep it out of the crank. Dennis
slantzilla@excite.com
 Post subject: Re: dipstick tips...
PostPosted: Mon Oct 28, 2002 8:49 pm
: OK, this is weird. but my 73 Dart (225 slant 6)
: has a dipstick that looks as if the end has
: been chewed off _ all the marks are missing.
: the socket is loose in the block, so the
: stick could move around...anybody else ever
: heard of this/have it happen?
The best "dipstick tip" I can give is to keep it away from the crank!
I can't count all the broken-off dipstick tips I have found in the bottom of a well used SL6 oil pans.
Yes, it's a somewhat common problem, that dipstick is no match for 76lbs of spinning SL6 crankshaft.
PostPosted: Tue Oct 29, 2002 2:21 pm
I have found they break off nice and clean at the full mark! If someone put a manifold on it 9 times out of 10 the dipstick tube gets bent and into the crank it goes.
One of the lttle quirks of a slant goes along with crackd exhaust manifolds well!
Sandy
sandy.colter@ns.sympatico.ca
PostPosted: Tue Oct 29, 2002 8:28 pm
: I have found they break off nice and clean at
: the full mark! If someone put a manifold on
: it 9 times out of 10 the dipstick tube gets
: bent and into the crank it goes.
: One of the lttle quirks of a slant goes along
: with crackd exhaust manifolds well!
: Sandy
My wife's '95 LHS has a cool dipstick I'd like to adapt to a sl/6. It's a cable with a crimped-on little torpedo shaped slug. Very readable, flexible, with a good sized yellow-colored t-handle on the end.
fglmopar@aol.com
Users browsing this forum: Bing [Bot] and 15 guests
