It is currently Mon Nov 17, 2025 12:20 pm
PostPosted: Thu Jul 27, 2006 7:18 am
I ran the car this past weekend for the 1st time at the Pittsburgh Chrysler Classic. I was running 16.3's - 16.4's all weekend. I ran a 16.21 in the first round of eliminations. I had to run the Mopar orange box because I was having problems with my msd 6al. When the car would shift into 3rd and running somewhere around 5,000 rpm's the mopar box would start to break up. Not a good choice to run on a drag car, but what are you going to do for a last minute repair. Not too bad for only getting the car running on Tuesday night. I also ran the edelbrock 500 carb right out of the box with no adjustments. Again, nothing like waiting for the last minute right? With a little test and tune time this car should run in the low 15's.
PostPosted: Thu Jul 27, 2006 6:59 pm
Wow, those are some pretty good times. Those late Dusters are heavy cars too. When I weighed my Duster it weighed over 3300#.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Thu Jul 27, 2006 7:12 pm
Those are very respectable times :D What's done to your slant??
PostPosted: Fri Jul 28, 2006 3:59 am
I like it! :D
Yeah, tell us some of the specifics on your car. Low 16s is really good.
Our '74 Duster (drag only) ran a 15.85 in Valdosta a couple months ago. It's got a mild performance build with a cam, 4 barrel, open headers and 3.91 gears. It weighs about 2,700 with the interior gutted.
PostPosted: Fri Jul 28, 2006 5:16 am
Car specs. 1974 Plymouth Duster with full interior & stock gas tank. 1971 225 block with .110 milled off the head, .100 milled off the block. Ported & polished head with 5 angle valve job on the intake, 3 angle valve job on the exhaust. Stock 340 valve springs, hardened valve seats, SI 1.70 intake valves, 1.44 exhaust valves, with teflon seals. Double roller timing chain from Huges Engines, MP 528" lift cam with 284 duration, centerlined at 101.5 degrees. 904 auto trans with MP shift kit, 1979 8 1/4 F Body rear with 4.10 Suregrip. Edelbrock 500 cfm carb, Clifford 4bbl intake, & Clifford long tube headers.
PostPosted: Fri Jul 28, 2006 5:32 am
I think low 16's was really good for the 1st time out. I would have been into the 15's if I did not have ignition problems. Forgot to mention I am also running a Midwest 3500 stall converter. I plan on hitting the test & tunes & make some changes to the carb & distributor. Thanks, Brian
PostPosted: Fri Jul 28, 2006 6:24 am
Brian,
dont forget to mention that you removed the front bumper to save some weight. removing that 150 pounds really helps.
PostPosted: Fri Jul 28, 2006 7:40 am
Great to see a new Slant racecar taking shape. Congrats on the buildup and great to meet you and hang out, Brian! Keep up the strong work. 15s are just around the corner...
PostPosted: Fri Jul 28, 2006 7:52 am
Good job Brian! :D
I'm thinking you should have a 14 second combination there. :D :D :D
PostPosted: Tue Aug 15, 2006 5:57 am
I finally had a chance to do some electrical work on the car and get my MSD box working right. I also had to adjust the timing a little. I'm just glad to get rid of the Mopar orange box, never had any luck with those. I planed on taking the car out and running the the flashlight drags this Saturday night, but the weather report is not looking good. Future upgrades will include a full manual valve body, 5 gal. fuel cell, 15" slicks and a diet plan.
PostPosted: Wed Aug 16, 2006 11:12 am
Mwahahahahah :lol: It's a disease I tell you! It will never end! But I like it. :D
Keep us posted on your progress!
PostPosted: Mon Sep 04, 2006 10:06 pm
whats you comp. ratio?
1975 Plymouth Duster,225/6 2bbl. and duels, 904, 7 1/4
1986 Dodge Charger Shelby, 2.2 Turbo I, A525
PostPosted: Mon May 21, 2007 6:57 am
I ran the car for the first time this year at the Columbus Chrysler Classic over the weekend. Fridays first run was a 15.7, spun sideways off the line due to tire pressure. 2nd run was a 15.62. Friday night I regapped the plugs to.045 and swapped metering rods. Saturdays first run was a 15.51, after swapping in a new fuel filter due to some junk in my fuel tank. I ran a best of 15.34 on the final time run. The only change I made to the car over the winter was install 18" header extensions.
 Post subject: Nice! 5-21-07
PostPosted: Mon May 21, 2007 3:59 pm
Nice improvement!
Now we are about to start runnin' Heads up!
Why dont you get a trailer and we go to pittsburgh Next wendsday for some Test and tune Slanty Style! It would be wild to see all the mustangs and ricer folks see a slant grudge match on a test n tune night!
Clean out yer crappy gas tank too!
If I can figure out how to race a stick I might be competitive with you!
Cheers! Greg
PostPosted: Mon Jul 16, 2007 8:12 am
I just got around to replacing that crappy gas tank with a brand spanking new one. Also added a set of M&H 235/60/14 on the rear and a new tach. :D
