It is currently Tue Nov 18, 2025 11:51 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
 Post subject: LONG ROD?
PostPosted: Sun Jan 13, 2002 1:37 pm
i saw in a machine shop longer rods that the ones in 198 cid...they are 20cm!!! from center to center..the piston pin is floating with a bushing...22 mm aproximately.
the rod was 3 cm wide fronm the bottom.
looked good quality, with good bolts etc.
you can find these from JAGUARS...if you can use that long rod in a de-stroked 225?
for what? i do not know, but it seems like you actually could find a better quality long rod maybe from a european engine...? have to investigate.
actually i could need a rod that is in midlle of 198 & 225 rod...do you know any that would suite a 225 crank??
jyri.eramaa@jwt.fi
PostPosted: Mon Jan 14, 2002 9:36 pm
The big problem with finding other rods to fit a SL6 is that the SL6 crank pin (rod journal) is real wide. It measures right around 1.210 inches so someone do the math, that 3 cm (or 30 mm) rod may be wide enough and 20 cm long, that almost 8 inches!
Are they forged steel?
Trouble is that I don't see many Jag engines in the junk yards around here!
: I saw in a machine shop longer rods that the
: ones in 198 cid...they are 20cm!!! from
: center to center..the piston pin is floating
: with a bushing...22 mm aproximately.
: the rod was 3 cm wide from the bottom.
: looked good quality, with good bolts etc.
: you can find these from JAGUARS...if you can
: use that long rod in a de-stroked 225?
: for what? i do not know, but it seems like you
: actually could find a better quality long
: rod maybe from a european engine...? have to
: investigate.
: actually i could need a rod that is in midlle
: of 198 & 225 rod...do you know any that
: would suite a 225 crank??
 Post subject: Re: LONG ROD?
PostPosted: Tue Jan 15, 2002 12:18 pm
There are others;
Chevy (big block?)
6.813 long 2.315 large end bore 1.429 width
forging # 3835274, 3835324, 3835609, 3701890
The width can be cut down no problem.
rvsrchjl@westriv.com
PostPosted: Tue Jan 15, 2002 1:34 pm
: There are others;
: Chevy (big block?)
: 6.813 long 2.315 large end bore 1.429 width
: forging # 3835274, 3835324, 3835609, 3701890
: The width can be cut down no problem.
I've seen 7"+ long rods for modified BB Chevy too, but I've never tried them. J&M engine dynamics in Nebraska, or Cox Bros in Ohio can get you custom hipo rods too.
Cheers,
madsenl@its.caltech.edu
PostPosted: Tue Jan 15, 2002 2:59 pm
: The big problem with finding other rods to fit
: a SL6 is that the SL6 crank pin (rod
: journal) is real wide. It measures right
: around 1.210 inches so someone do the math,
: that 3 cm (or 30 mm) rod may be wide enough
: and 20 cm long, that almost 8 inches!
: Are they forged steel?
: Trouble is that I don't see many Jag engines in
: the junk yards around here!
: DD
i have to ask...
i would think so...if im right the jag has a 4.2 liters engine??? was it so, that could be ... and it has over 200 hp in stock... e-type?
have to check.
jyri.eramaa@jwt.fi
