It is currently Tue Nov 18, 2025 8:31 pm
 Post subject: Piston L2125 info?
PostPosted: Mon Jan 14, 2002 9:50 am
Hi,
Anyone recognize the L2125 number from the top of my pistons? I'd guess maybe a TRW piston? Flat top, no valve reliefs.
Anyone have technical info on these? Compression height, forged/cast, etc?
thanks in advance,
mark
mldingba@collins.rockwell.com
 Post subject: Re: Piston L2125 info?
PostPosted: Mon Jan 14, 2002 1:37 pm
: Anyone recognize the L2125 number from the top
: of my pistons? I'd guess maybe a TRW piston?
: Flat top, no valve reliefs.
Yep, you're right. TRW pistons....is there any indication of the letter F behind the 5? I know that piston was offered in a forged version, but am unsure if the cast was a different number, or the only difference was the "F" designation.
: Anyone have technical info on these?
: Compression height, forged/cast, etc?
Doug might be able to help here, sorry.
Roger
GTS225@aol.com
PostPosted: Mon Jan 14, 2002 6:34 pm
: Hi Mark, I looked the L2125F pistons up in the TRW Specifications book. They are as followes: Comp. Dist. 1.752", Powerforged, 2-5/64" and 1-3/16" rings, .9011" pin dia. I hope this answers your questons. Doug
: thanks in advance,
: mark
Valient64@aol.com
 Post subject: Thanks! No message *NM*
PostPosted: Tue Jan 15, 2002 6:36 am
