It is currently Tue Nov 18, 2025 11:49 am
PostPosted: Sun Jan 20, 2002 3:13 pm
I need someone to e mail me or post a picture of the plug wiring diagram.I just cant get it wired or timed right. One other guestion , with the #1 piston up where is the rotary button supposed to be setting. I can get it started but runs rough.New carb, plugs,wires etc. etc.PLEASE HELP.
hillbillygirl@triad.rr.com
PostPosted: Mon Jan 21, 2002 10:31 am
: I need someone to e mail me or post a picture
: of the plug wiring diagram.I just cant get
: it wired or timed right. One other guestion
: , with the #1 piston up where is the rotary
: button supposed to be setting. I can get it
: started but runs rough. New carb, plugs,wires
: etc. etc.PLEASE HELP.
The firing order is 1 5 3 6 2 4
The number one spark plug wire is positioned at the "4:30" position, although you could wire from any possible position as long as you find TDC compression and follow the firing order.
If you have it running, you should be able to adjust it in with a timing light. Remember, there is another adjustment bolt and slot on the bottom "backside" of the distributor.
Users browsing this forum: No registered users and 15 guests
