It is currently Thu Nov 20, 2025 1:42 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
 Post subject: dics brakes
PostPosted: Tue Jan 22, 2002 2:24 pm
hey guys I just got a dics brakes setup from a 72 duster. Can I use the spindle from that on my car 69 dart? the spindle is the only difference in the suppension that I can see or am I missing something.
andrew wagner
 Post subject: Re: dics brakes
PostPosted: Tue Jan 22, 2002 3:12 pm
: hey guys I just got a dics brakes setup from a
: 72 duster. Can I use the spindle from that
: on my car 69 dart? the spindle is the only
: difference in the suppension that I can see
: or am I missing something.
: andrew wagner
If the 72 is the 4 piston "fixed position" calipers then yes, change everything from the spindle on out. You will need 14 inch wheels to clear the disc caliper and a disc brake porportioning valve will need to be added to "balance" the front to rear braking force.
PostPosted: Tue Jan 22, 2002 3:24 pm
yes!!!!!!!!!!!!!! thank you I was begining to think I messed up and bought the wrong thing.
thanks again!!!!!!!!!!!!!!!!!!!
andrew wagner
: If the 72 is the 4 piston "fixed
: position" calipers then yes, change
: everything from the spindle on out. You will
: need 14 inch wheels to clear the disc
: caliper and a disc brake porportioning valve
: will need to be added to "balance"
: the front to rear braking force.
: DD
PostPosted: Tue Jan 22, 2002 4:23 pm
: yes!!!!!!!!!!!!!! thank you I was begining to
: think I messed up and bought the wrong
: thing.
: thanks again!!!!!!!!!!!!!!!!!!!
: andrew wagner
Dics brakes?? Sounds painful...
madsenl@its.caltech.edu
PostPosted: Wed Jan 23, 2002 4:03 pm
: Dics brakes?? Sounds painful...
: Lou
my back is killing me!!!!!!!!!!!!!!!
andrew
