It is currently Wed Nov 19, 2025 11:58 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
PostPosted: Tue Feb 05, 2002 5:26 pm
I would like to use a cigarette lighter DC to AC inverter that uses 11-15VDC, in my 63' Valiant.
Is this safe for the electrical system?
Thanks,
Robert.
countchocula@forpresident.com
PostPosted: Tue Feb 05, 2002 11:19 pm
: I would like to use a cigarette lighter DC to
: AC inverter that uses 11-15VDC, in my 63'
: Valiant.
: Is this safe for the electrical system?
I've never owned a 1963, but both my 1962 and my '64 have 16 gauge wire supplying the cigar lighter. I would expect 16 gauge wire to carry 15 Amps. In 1962, the lighter circuit is fused at 14 Amps, and in 1964 they use a 20 Amp fuse for the same circuit. 20 Amp for a short period of time, say a couple minutes, is probably Ok, but if you load a 16 gauge wire with 20 Amps continuously, it will get hot and melt the insulation.
If 15 Amps is safe, 15 x 12 = 180 watts.
I doubt your inverter is more than 80% efficient, so 180 watts in equals 144 watts out. If you use the inverter to power anything bigger than 144 watts, you may have trouble. At best, 20 Amps into a 100% efficient inverter is 240 watts.
Dave W.
dwordinger@earthlink.net
PostPosted: Wed Feb 06, 2002 3:13 am
: I've never owned a 1963, but both my 1962 and
: my '64 have 16 gauge wire supplying the
: cigar lighter. I would expect 16 gauge wire
: to carry 15 Amps. In 1962, the lighter
: circuit is fused at 14 Amps, and in 1964
: they use a 20 Amp fuse for the same circuit.
: 20 Amp for a short period of time, say a
: couple minutes, is probably Ok, but if you
: load a 16 gauge wire with 20 Amps
: continuously, it will get hot and melt the
: insulation.
: If 15 Amps is safe, 15 x 12 = 180 watts.
: I doubt your inverter is more than 80%
: efficient, so 180 watts in equals 144 watts
: out. If you use the inverter to power
: anything bigger than 144 watts, you may have
: trouble. At best, 20 Amps into a 100%
: efficient inverter is 240 watts.
: Dave W.
Just go get an aux. lighter socket & heavy guage wire & install to battery (fused, of course) I did this to the trunk area to power various 12 volt accessories. Remember, if you are not running the car , you better have a decent battery!
ktbarnwell1@juno.com
