It is currently Tue Nov 18, 2025 8:33 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: Camshaft selection
PostPosted: Wed Feb 06, 2002 8:02 pm
I'm not sure what cam I should go with on my 225 slant six. Basically I have a stock bottom end I've polished my head decked it .060" and done a competition valve grind. I drive this car as a daily driver any suggestions
craig_o_connor88@hotmail.com
PostPosted: Thu Feb 07, 2002 12:37 pm
: I'm not sure what cam I should go with on my
: 225 slant six. Basically I have a stock
: bottom end I've polished my head decked it
: .060" and done a competition valve
: grind. I drive this car as a daily driver
: any suggestions.
We need a little more info. here:
What carb.?
What exhaust?
What is the trans, if an automatic, what converter stall speed.
What rear end gear ratio.
Sounds like you want a "street performance" cam that gives a little more RPM while not giving-up idle quality and low speed torque.
 Post subject: Re: Camshaft selection
PostPosted: Thu Feb 07, 2002 8:51 pm
: any suggestions
That #3 crane cam looks pretty weak to me. 280* duration with ONLY 218*@50? Shivvy lobe! I thought a 268 Purple Shaft would be a nice size cam in my /6, but you can hardly tell it's there unless you wind it up at WOT. If you want a decent cam, I'd suggest a 268 Purple Shaft if you can find one, or maybe an isky cam like other people have used. You say you polished the head and did a valve job, but did you port it or get someone else to? How about gasket matching? A LOT needs to come out of the exhaust ports just to match the factory manifold.
