It is currently Tue Nov 18, 2025 8:35 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
 Post subject: Camshaft selection
PostPosted: Thu Feb 07, 2002 1:15 pm
I have a 225 slant six in my 72 duster that I bought about a year ago. I've polished the head decked it 0.060" and done a competition valve grind. I upgraded from the single barrel to a super six setup. I've got a 7 1/4 rear end not sure of the ratio and an automatic tranny. The drive line is pretty much factory no mods. Any suggestions on a camshaft. I'm looking for a good street performance cam nothing really wild
craig_o_connor88@hotmail.com
 Post subject: Re: Camshaft selection
PostPosted: Thu Feb 07, 2002 1:18 pm
: I have a 225 slant six in my 72 duster that I
: bought about a year ago. I've polished the
: head decked it 0.060" and done a
: competition valve grind. I upgraded from the
: single barrel to a super six setup also I have the factory exhaust 2 1/4". I've got
: a 7 1/4 rear end not sure of the ratio and
: an automatic tranny. The drive line is
: pretty much factory no mods. Any suggestions
: on a camshaft. I'm looking for a good street
: performance cam nothing really wild
PostPosted: Thu Feb 07, 2002 1:46 pm
I've been looking at a cam that crane cams makes
<A HREF="http://www.cranecams.com/master/apps/ch ... 2.htm#3</A>. PowerMax
is this too much cam for my engine it's #3 on the list
PostPosted: Thu Feb 07, 2002 4:55 pm
: I've been looking at a cam that crane cams
: makes
: <A HREF="http://www.cranecams.com/master/apps/chrys2.htm#3">http://www.cranecams.com/master/apps/chrys2.htm#3</A>
: . PowerMax
: is this too much cam for my engine it's #3 on
: the list
A pretty good (mild) choice for a "one step-up" street performance set-up. I never liked the .022 & .022 lash settings on the Cranes, always seem to run these a bit tighter on the intakes. ( .016 to .018 )
PostPosted: Thu Feb 07, 2002 10:34 pm
: A pretty good (mild) choice for a "one
: step-up" street performance set-up. I
: never liked the .022 & .022 lash
: settings on the Cranes, always seem to run
: these a bit tighter on the intakes. ( .016
: to .018 )
: DD
Yep, I would barely call that #3 a performance cam. The #4 cam (228 deg @ 0.050") is pretty good, especially with a 2400 RPM or more stall converter or a stick. Idle is still smooth.
