It is currently Wed Nov 19, 2025 2:22 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
 Post subject: 66' valiant
PostPosted: Mon Feb 11, 2002 7:37 pm
66' been sitting for 4 yrs ,cam turns ,new plugs /points ,battery . lights won,t come on ,or crank. Live on the coast ,so the rust might have affected the grounds . Where do I start .How do i test the resistor ? help !!!! matt g
gholsonfour@msn.com
 Post subject: Re: 66' valiant start-up
PostPosted: Tue Feb 12, 2002 4:58 pm
: 66' been sitting for 4 yrs ,cam turns ,new
: plugs /points ,battery . lights won,t come
: on ,or crank. Live on the coast ,so the rust
: might have affected the grounds . Where do I
: start .How do i test the resistor ?
Sounds like a bad fuseable link or alturnator gauge.
Will the engine crank if you connect the two wire posts comming out of the starter? (bridge them with a screwdriver or piece of metal) Give that a try, if it cranks, hotwire the coil and see if it will start.
PostPosted: Tue Feb 12, 2002 6:46 pm
: Sounds like a bad fuseable link or alturnator
: gauge.
: Will the engine crank if you connect the two
: wire posts comming out of the starter?
: (bridge them with a screwdriver or piece of
: metal) Give that a try, if it cranks,
: hotwire the coil and see if it will start.
: DD
havent tried bridging starter yet ,but shouldnt the lights or turn signals work w/out starting ?
gholsonfour@msn.com
PostPosted: Wed Feb 13, 2002 6:30 am
: havent tried bridging starter yet ,but shouldnt
: the lights or turn signals work w/out
: starting ?
If the alt gauge is bad, or terminals loose or broken, then nothing will work.
madsenl@its.caltech.edu
PostPosted: Fri Feb 22, 2002 9:06 pm
: start .How do i test the resistor ? help
: !!!! matt g
Try wiggling your bulkhead connector. A common problem in old mopars is corrosion of the connector of the main power wire running through the ammeter.
Drew
rdb787@mail.usask.ca
