It is currently Tue Nov 18, 2025 6:45 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: Roller camshafts
PostPosted: Tue Feb 19, 2002 3:07 pm
In your artical about stroking the slantsix in the stroker 170 section, there was a comment about a roller cam. I am very interested in finding out were to get such a thing along with the related valve train. I have a 360 in a duster that has one. What a difference. I can't see why anyone would put in a flat tappet cam if you had the choice of a roller. Any information on the subject will be used in my next slanter project.
Thanks bparsons
bparsons@coi-world.com
 Post subject: Re: Roller camshafts
PostPosted: Tue Feb 19, 2002 11:14 pm
I think you have to make the entire cam shaft using a custom steel core. I think cast iron is too soft. I don't think these are commercially available! I think you will have to find a machinist to make this part.
I saw an article in Hot Rod magazine which stated some advantages of using roller bearings to replace the babbet. If you're going to spend money in a motor there's plenty of ways to do it!
: In your artical about stroking the slantsix in
: the stroker 170 section, there was a comment
: about a roller cam. I am very interested in
: finding out were to get such a thing along
: with the related valve train. I have a 360
: in a duster that has one. What a difference.
: I can't see why anyone would put in a flat
: tappet cam if you had the choice of a
: roller. Any information on the subject will
: be used in my next slanter project.
: Thanks bparsons
tkeith@mindspring.com
PostPosted: Thu Feb 21, 2002 1:56 pm
: Thanks bparsons
I have my roller cam core (cast steel) project moving again. I will post some additional info. when I get back to my home computer. (next week)
I am like you, once you run a roller, there is no going back to flat tappet cams.
PostPosted: Fri Mar 08, 2002 6:05 am
Are you slill working on the project or is it on hold again?
