It is currently Tue Nov 18, 2025 6:52 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
 Post subject: Conversion U-joint
PostPosted: Mon Feb 25, 2002 2:12 pm
Does anyone have a part # for the conversion U-joint, for the small joint to large joint.Is it available at the local auto parts stores or is it a special item that has to be purchase elsewhere. Thanks for any help.
Rick
rcovalt@innernet.net
 Post subject: Re: Conversion U-joint
PostPosted: Mon Feb 25, 2002 4:56 pm
: Does anyone have a part # for the conversion
: U-joint, for the small joint to large
: joint.Is it available at the local auto
: parts stores or is it a special item that
: has to be purchase elsewhere.
Should be available from your local parts store, they need a u-joint to join a 7260 (small) to a 7290 (large) yoke. If you have a good parts store or some one who knows mopars they will know exactly what u-joint you need..
good hunting,
PostPosted: Tue Feb 26, 2002 4:33 pm
: Should be available from your local parts
: store, they need a u-joint to join a 7260
: (small) to a 7290 (large) yoke. If you have
: a good parts store or some one who knows
: mopars they will know exactly what u-joint
: you need..
: good hunting,
: -D.Idiot
If the auto parts store doesn't have one, try a driveshaft shop.
thelogs@cox.net
PostPosted: Tue Feb 26, 2002 4:40 pm
napa has them I will try to find the number. I have it written down somewhere.
Will
: has to be purchase elsewhere. Thanks for any
: help.
: Rick
slantsix@netzero.net
PostPosted: Wed Feb 27, 2002 5:00 am
: If the auto parts store doesn't have one, try a
: driveshaft shop.
Lakewood used to list it in thier catalog, so Summit and Jegs should have it. Precision is another brand to check.
marc_medina@hotmail.com
