It is currently Mon Nov 17, 2025 11:02 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
PostPosted: Wed Mar 06, 2002 2:46 pm
I need to install a new oil pan for my 63 Valiant's 225.
I picked up a pan and pickup tube at a swap meet.
Recently I realized that not all /6 oil pans are the same. The pan I bought is stamped with the number 987.
I have the pan painted. I have the oil pan gasket set. I thought I was ready to go.
Will this work? Do I need to replace anything else?
Does anyone have any tips on removing the pan while the engine is in the car?
While I'm doing this, should I go ahead and do anything else since I'm already there?
Thanks for any help.
John Killin
Killin5@yahoo.com
 Post subject: Re: SL6 Oil Pans *PIC*
PostPosted: Wed Mar 06, 2002 10:29 pm
: I need to install a new oil pan for my 63
: Valiant's 225.
: I picked up a pan and pickup tube at a swap
: meet.
: Recently i realized that not all /6 oil pans
: are the same. The pan I bought is stamped
: with the number 987.
: I have the pan painted. I have the oil pan
: gasket set. I thought I was ready to go.
: Will this work? Do I need to replace anything
: else?
: Does anyone have any tips on removing the pan
: while the engine is in the car?
: While I'm doing this, should I go ahead and do
: anything else? since I'm already there.
Sorry to say that the "987" pan is one of the pans for the 67 and later A-Body cars, this pan will not fit 60-66 A-Body chassis.
As for other things to check or do when the pan is off, a new set of con rod bearings is good "insurance". Also clean-out your oil pick-up tube completly.
If it were me, I would pull the engine to do this swap because dropping all the steering linkage to get the pan off is a real pain. Then you have to deal with getting the 4 part oil pan gasket to align correctly, with oil dripping on you the whole time. It can be done but it is no fun.
Here is a look at the pan you have next to the one you need. The early A-Body pan has a much longer front section.
FYI, the only other pan that will fit is the "369", mid 70s A & F body unit, the blue one in this pic. The front left corner of that pan comes close to the 60-66 K-frame so I dent it in a little to make clearance. (see the black lines)
PostPosted: Sat Mar 16, 2002 4:13 pm
: Sorry to say that the "987" pan is
: one of the pans for the 67 and later A-Body
: cars, this pan will not fit 60-66 A-Body
: chassis.
: As for other things to check or do when the pan
: is off, a new set of con rod bearings is
: good "insurance". Also clean-out
: your oil pick-up tube completly.
: If it were me, I would pull the engine to do
: this swap because dropping all the steering
: linkage to get the pan off is a real pain.
: Then you have to deal with getting the 4
: part oil pan gasket to align correctly, with
: oil dripping on you the whole time. It can
: be done but it is no fun.
: Here is a look at the pan you have next to the
: one you need. The early A-Body pan has a
: much longer front section.
: FYI, the only other pan that will fit is the
: "369", mid 70s A & F body
: unit, the blue one in this pic. The front
: left corner of that pan comes close to the
: 60-66 K-frame so I dent it in a little to
: make clearance. (see the black lines)
: DD
What is the number on the bottom of the early A-body pan? Thanks, Darrin
dartman225@webtv.net
PostPosted: Mon Mar 18, 2002 10:42 am
: What is the number on the bottom of the early
: A-body pan? Thanks, Darrin
There is no number stamped into the early A-Body oil pans. You just have to look for the long shallow front section, the sump does not start until appx the 3rd bolt hole back.
PostPosted: Sun Apr 07, 2002 12:21 pm
: chassis.
: DD
So for a 62 Lancer, should I be looking for the red one (top left) or the burgandy one (top right)? Are the pick-ups any different or caon they be interchanged? Thanks! Darrin
