It is currently Mon Nov 17, 2025 8:37 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: Sat Mar 23, 2002 5:41 pm
My 63' Valiant has been dying on me when it warms up, so I replaced the condensor, but that hasn't solved it. It keeps doing it, but now i've noticed that when it happens the gas is boiling in the carburetor. I remember that boiling gas is symptomatic of a common problem...but I can't remember what is. Any suggestions?
thanks
Rebecca
PostPosted: Sat Mar 23, 2002 11:52 pm
: I
: remember that boiling gas is symptomatic of
: a common problem...but I can't remember what
: is. Any suggestions?
: thanks: Rebecca
Look into the possibility of vapor lock. Excessive heat in the fuel lines or the carb can make the gas boil into vapor, stopping delivery to the carb. It won't start until things cool back down, and occasionally, not even then.
Back-track your fuel lines and check how close they are mounted to the block or exhaust, take steps to correct if needed. You might also try a very thick carb base gasket. It will act as an insulator for the carb.
Roger
GTS225@aol.com
