It is currently Mon Nov 17, 2025 1:01 pm
 Post subject: removing oil pan
PostPosted: Thu Apr 04, 2002 3:48 am
never had to do it before, wondering if there is anything "in the way" when removing oil pan?
SlantedSix225@aol.com
PostPosted: Thu Apr 04, 2002 10:56 am
: never had to do it before, wondering if there
: is anything "in the way" when
: removing oil pan?
The steering centerlink and the K-frame are "in the way". (at least in a A-Body car)
PostPosted: Fri Apr 05, 2002 6:42 pm
: The steering centerlink and the K-frame are
: "in the way". (at least in a
: A-Body car)
: DD
the stearing link and K-frame arent a problem on my 85 d-150 but there is a bracket on the drivers side that connects the trans(mines an 833od) and the motor that when i took off my truck the oil pan had a very easy time coming out.
dodgecrazy@aol.com
 Post subject: Re: removing oil pan
PostPosted: Sun Apr 07, 2002 6:42 pm
Drop the idler and pitman, loosen the motor mounts and jack up the motor from the front pulley.
Chuck
: removing oil pan?
webmaster@omnipages.com
