It is currently Tue Nov 18, 2025 2:22 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
PostPosted: Tue Apr 09, 2002 8:26 am
Hi Gang,
I want to know if I can use a dash wiring harness from a 69 Dart GTS in a 66 Dart GT. Any other issues I should be concerned with? My fuse block is a little rusty (flaky) and it appeared that there was a short in it at one time since the plug to the light switch has melted plastic. I figure I will replace the voltage limiter in the instrument panel and the headlight switch at the same time. BTW: anyone know where to order a voltage limiter from? Also, If I bypass the ammeter by connecting the 2 leads, do they still have to be attached to the instrument panel or can I just attach the wires together (independent from the instrument panel)?
kimpelt@pdx.edu
PostPosted: Wed Apr 10, 2002 2:44 pm
The second generation A-body (1963-66 Dart) and third generation A-body (1967-76) dash wiring harness do not directly interchange. The wiring color is typically the same for the specified function, but the connectors are too different.
--Walt Jackson
WalterLeeJackson@compuserve.com
PostPosted: Wed Apr 10, 2002 3:37 pm
: Hi Gang,
: I want to know if I can use a dash wiring
: harness from a 69 Dart GTS in a 66 Dart GT.
No, these are different and will not swap.
: My fuse block is a little rusty (flaky) and
: it appeared that there was a short in it at
: one time since the plug to the light switch
: has melted plastic.
The fuse block itself can be replaced or repaired, I recently cleaned and repaired a melted one using high temp two part epoxy to support the fuse holder "prongs". I did it without pulling the harness from the car. (I did have to unclip the wire bundles and unscrew the fuse block mount, then pulled it down where I could get at it) The headlight plug can be replaced, make a wiring "map" and push-out each wire, ("trip" the holding sper) then re-install the wires into a replacement plastic plug using your "map".
: I figure I will replace
: the voltage limiter in the instrument panel
: and the headlight switch at the same time.
: BTW: anyone know where to order a voltage
: limiter from?
Good question, have you tried the dealer? It the same limiter for many years and models.
: Also, If I bypass the ammeter
: by connecting the 2 leads, do they still
: have to be attached to the instrument panel
: or can I just attach the wires together
: (independent from the instrument panel)?
You can just attach the two wires, I use a #10 pan head screw and nut, through the wire eyelets, then wrap with electrical tape and shrink tube. A fast way is to just put both wires on one of the ammeter's posts so you do not have to find a seperate screw to use.
