It is currently Tue Nov 18, 2025 8:13 pm
PostPosted: Wed May 15, 2002 11:49 am
Where can I get a high performance clutch and pressure plate assembly for my slant six powered '71 Demon???
Demonboy71@yahoo.com
PostPosted: Wed May 15, 2002 11:51 am
: Where can I get a high performance clutch and
: pressure plate assembly for my slant six
: powered '71 Demon???
Remember I need a high performance assembly ready to be drag raced...
PostPosted: Wed May 15, 2002 2:07 pm
: Remember I need a high performance assembly
: ready to be drag raced...
Check out Mcleod Industries (www.mcleodind.com). They can set you up with a 10" setup for your stock flywheel. Info below.
714-630-2764
714-630-5129 FAX
714-630-3668 Tech Service
1600 Sierra Madre Circle
Placentia, CA 92870
Cheers,
PostPosted: Wed May 15, 2002 4:02 pm
The 10 inch set-up will bolt right in and can be made plenty stiff for a SL6.
There are lots of custom clutch builders out there, call around. (see the link below for the shop I use out here in California)
Local parts store can order the pressure plate as APRA p/n 351525 or 361525,
the disc is a little harder to find for the Mopar 23 spline (# 3082??)
Jump to another Message
PostPosted: Thu Aug 22, 2019 3:04 pm
Car Model: barracuda
south bend clutch
PostPosted: Thu Aug 22, 2019 5:19 pm
Thanks for posting, and welcome to the site, Mr. Upnover.
Do you have experience with South Bend Clutch? Looks like a serious place...
PostPosted: Thu Aug 22, 2019 5:32 pm
Some discussion on the topic here:
http://www.slantsix.org/forum/viewtopic ... nd#p479333
Users browsing this forum: Ahrefs [Bot] and 7 guests
