It is currently Mon Nov 17, 2025 2:36 am
 Post subject: Stroker crank
PostPosted: Thu May 23, 2002 7:30 pm
Doctor D,
Do you sell the stroker crank kit? If so, how can I get more information about?
kurtz@uri.edu
PostPosted: Fri May 24, 2002 3:05 am
: Do you sell the stroker crank kit? If so, how
: can I get more information about?
The Stroker Cranks I have made over the years were done on an "as needed" basis and in general are expensive to do. ($800 to $1,000.00 just for a crank)
PostPosted: Fri May 24, 2002 3:29 pm
How do you like the stroked engine? Is it much stronger? Are there problems? Do you use a 2b carb? I want to use mine for a 3/4 ton '68' dodge mail truck van.
kurtz@uri.edu
