It is currently Tue Nov 18, 2025 2:35 am
 Post subject: Rod Info Needed
PostPosted: Fri May 24, 2002 4:53 pm
I received my Rods today that are supposed to be 198 Rods.The #1947167 is on the side of the Rod & #65 on the other side.Can someone tell me what Rod i have ?,it does not measure 7" center of piston pin to center of Rod ,more like 6"..........arthur
coinjockey@webtv.net
 Post subject: Re: Rod Info. & 170 Rods
PostPosted: Fri May 24, 2002 5:34 pm
: I received my Rods today that are supposed to
: be 198 Rods.The #1947167 is on the side of
: the Rod & #65 on the other side.Can
: someone tell me what Rod i have ?,it does
: not measure 7" center of piston pin to
: center of Rod ,more like
: 6"..........arthur
That is the 170 forging number, these should be 5.7 inches long.
Al's revised table has this info. (see the link)
(We did find a way to convert this table into a small printable file so we will add it to the article section once Chuck returns)
Al's SL6 Application Table
