It is currently Mon Nov 17, 2025 3:57 am
 Post subject: Int/Exh torque again?
PostPosted: Mon May 27, 2002 10:58 am
Looking at a long block on my engine stand, and am wondering about the possibility of replacing the int/exh studs with bolts. Thinking that if I'm hanging split man's or headers, with an alum. intake, would the bolt torque be anywhere near so critical anymore?
Any advice/thoughts/theories?
Roger
GTS225@aol.com
PostPosted: Mon May 27, 2002 1:05 pm
: Looking at a long block on my engine stand, and
: am wondering about the possibility of
: replacing the int/exh studs with bolts.
: Thinking that if I'm hanging split man's or
: headers, with an alum. intake, would the
: bolt torque be anywhere near so critical
: anymore?
: Any advice/thoughts/theories?
Leave the studs in Roger, mostly because all those holes go into the waterjacket You don't want to run the chance of wearing out theaded holes and fighting leaks.
You can buy higher quality studs but the reason for the low factory torque spec is to allow the stock cast iron exhaust manifold to move, really to slide accross the gaskit as it heats and cools.
Intake manifolds and headers do not really need to slide so you can clamp down on the nuts a bit harder with them.
PostPosted: Mon May 27, 2002 1:45 pm
: Leave the studs in Roger, mostly because all
: those holes go into the waterjacket You
: don't want to run the chance of wearing out
: theaded holes and fighting leaks.
************************************************** Ok.....I'll do the aftermarket option and "glue" them in. Three of them came out when I seperated the original manifold assy from the head
: Intake manifolds and headers do not really need
: to slide so you can clamp down on the nuts a
: bit harder with them.
************************************************** That was my train of thought, too......just wanted to check my "logic". Thanks, Doug
Roger
GTS225@aol.com
PostPosted: Mon May 27, 2002 7:44 pm
I was just removing those same 'pesky' studs today, and I was just thinking about a better grade stud, because two were broken in the head. And lo, 'the Doctor' mentions better quality studs. Does ARP make the appropriate size grade 8+ whatever int/exh studs? While I am in the neighborhood, you once mentioned coming up with the PN's for other ARP fasteners for sl/6's. Did I miss it?
: You can buy higher quality studs but the reason
: for the low factory torque spec is to allow
: the stock cast iron exhaust manifold to
: move, really to slide accross the gaskit as
: it heats and cools.
: DD
fglmopar@aol.com
Users browsing this forum: Google [Bot] and 41 guests
