It is currently Sun Nov 16, 2025 11:38 pm
 Post subject: Hey Mike and Blaine!!!!
PostPosted: Sun Jun 02, 2002 4:30 pm
I'm quietly sneaking up on the 14's. I put the spacer on this week, and tried it out with the same jetting as last week. 58/60 Conditions were real close to last week too, C/A 1800'. Car ran about a tenth better. 15.33 last week, 15.23 this week. I put some more jet in 60/63 and it ran 15.12, and backed it up with a 15.13 after the headwind kicked up. (15mph, can't be at 41 without a good headwind) I have a points race at RT66 next weekend and I'll have my exhaust dump in then so I can open the header. If we have any kind of weather, the 14's are mine!!!!! Dennis
slantzilla@excite.com
PostPosted: Sun Jun 02, 2002 9:45 pm
: I'm quietly sneaking up on the 14's. I put the
: spacer on this week, and tried it out with
: the same jetting as last week. 58/60
: Conditions were real close to last week too,
: C/A 1800'. Car ran about a tenth better.
: 15.33 last week, 15.23 this week. I put some
: more jet in 60/63 and it ran 15.12, and
: backed it up with a 15.13 after the headwind
: kicked up. (15mph, can't be at 41 without a
: good headwind) I have a points race at RT66
: next weekend and I'll have my exhaust dump
: in then so I can open the header. If we have
: any kind of weather, the 14's are mine!!!!!
: Dennis
That's great news! Sounds like me a some years ago. I always wondered if I could run in the 14 second bracket and I finally made it. Than I wondered if I could ever get in the 13 second bracket and sure enough I made it. I told myself 12's no way I'd have to be on some good drugs.... guess what? I made it. Their is alot of Horse Power in that old slant and the fun part is looking for it and than finding it. keep up the good work.
damuel@kalama.com
PostPosted: Mon Jun 03, 2002 4:28 am
Thanks Dave! I never intended to get this deep in Slant racing, I gues I spent too much time with Mike and Blaine, huh? Next trick is gonna be to start spraying. I'm thinking I'll at least get deep into the 13's then. Dennis
 Post subject: How Deep ?
PostPosted: Mon Jun 03, 2002 10:23 pm
: Thanks Dave! I never intended to get this deep
: in Slant racing, I gues I spent too much
: time with Mike and Blaine, huh? Next trick
: is gonna be to start spraying. I'm thinking
: I'll at least get deep into the 13's then.
: Dennis
Then 12.000? Then 11.000?? The only end I have found is when the race track will not let you race any more because you are too old.
damuel@kalama.com
 Post subject: Re: How Deep ?
PostPosted: Fri Jun 07, 2002 8:48 pm
: Then 12.000? Then 11.000?? The only end I have
: found is when the race track will not let
: you race any more because you are too old.
Hey Dennis sounds like your doing well are you going to hamilton? if so see you there
BLAINEMUELLER1@netscape.net
 Post subject: Re: How Hard?
PostPosted: Sat Jun 08, 2002 11:23 am
: Hey Dennis sounds like your doing well are you
: going to hamilton? if so see you there
Hi Blaine,
Did those special oil pump gears get to you and Mike?
(check this webpage out:)
<A HREF="http://www.slantsix.org/articles/oil-pump-gear/failure-fix-report.htm">http://www.slantsix.org/articles/oil-pump-gear/failure-fix-report.htm</A>
Boy... I wanted to get to Hamilton this year but it's not going to work for me, I need to get positioned to get out to Clay City, I think I can swing that. How about you guys?
PostPosted: Sat Jun 08, 2002 9:32 pm
: Hi Blaine,
: Did those special oil pump gears get to you and
: Mike?
: (check this webpage out:)
: <A HREF="http://www.slantsix.org/articles/oil-pu ... ort.htm</A>
: Boy... I wanted to get to Hamilton this year
: but it's not going to work for me, I need to
: get positioned to get out to Clay City, I
: think I can swing that. How about you guys?
: DD
Hi Doug yes we got the gears i think we are going to have them coated yes we are going to clay city catch you later
