It is currently Tue Nov 18, 2025 8:50 pm
 Post subject: Manifold
PostPosted: Thu Sep 06, 2007 8:14 pm
Since fuel injectors are going to be used for fuel supply does it matter whether a 1barrel or 2barrel or 4barrel intake is used?
Go for it, You live this life only once.
PostPosted: Thu Sep 06, 2007 9:42 pm
Maybe. The factory 1 and 2 bbls have similar runner length and cross section. You'd have to machine the tb inlet to match your choice. If you go with a 4 bbl, the runners will most likely be larger in diameter. Of course, availability would have a lot to do with choice as well.
Mike
Recognized by US Federal Courts as a Fuel Economy Expert!
PostPosted: Fri Sep 07, 2007 9:07 am
Well, the 1 bbl would need a bit of machining to fit a decent sized throttle body on it. I take it this is port injection, not a TBI?
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Fri Sep 07, 2007 10:47 am
I used a new Clifford manifold, it has injector bosses cast on the manifold and mounts for a fuel rail. It was fairly easy to make adapter for a throttle body.
1966 Signet
Turbo Slant Six
PostPosted: Fri Sep 07, 2007 3:21 pm
If I use the clifford intake is there any way I can get around useing the headers because I dont want headers.
PostPosted: Fri Sep 07, 2007 5:30 pm
You don't have to use headers, but you can't use the stock exhaust manifold. The clifford intake has a water passage on the bottom of the plenum that will hit the stock exhaust.
PostPosted: Sat Sep 08, 2007 5:05 am
Dutra duals are what I used with the Clifford intake, but some clearance work was needed to get the rear flange to fit with a mini-starter. It was not hard, but took time, and a mini starter was required which is an added expense. This entire project was quite expensive by the time it was all done. I can't remember exactly, but I think I paid about $300 for the Dutra duals, and around $200 for the intake from Clifford, and $120 for the starter. And then there was custom exhaust work. I paid $200 for prebent 340 exhaust pipes and then about $200 for custom head pipes to be bent. There you go; over $1000 for intake and exhaust before I spent a dime on the EFI or turbo stuff.
Sam
PostPosted: Sun Sep 09, 2007 6:48 am
You are running Dutra's feeding the turbo?
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Mon Sep 10, 2007 4:08 am
Hi,I used a two barrel manifold with a single 65mm throttle body.I made a alloy 3/8 plate with counter sunk cap screws into the manifold.If its mounted with the spindle across (east/west) the linkage is easy to build.
