It is currently Mon Nov 17, 2025 6:33 pm
PostPosted: Tue Jul 16, 2002 2:55 pm
Hi
I'm new to car fixology and would appreciate your help. I picked up all the stuff I need to do a tune-up (including a book which told me what to do). It also told me to either check a spec sheet at the place I buy my parts or call a garage.
I tried both of those, and nobody seemed to be able to give me info (or just didn't want to). Where else can I find info on my car? I can't find the owner's manual. It's a 1966 Coronet with a 225.
I've got the correct plug gap of .30, but don't know the correct dwell, point gap, timing and - hmm, I'm pretty sure there was something else I need but don't remember. Is there somewhere online that has this info or might someone out there happen to have that info?
I sure appreciate any help. As a side note, this past weekend I managed to pull, evaluate, clean and re-gap my own sparkplugs. I'm quite impressed with me. Up to this point, the only thing I've ever done is put gas in one hole and a key in another (and I'm sure I've even come close to mixing those up from time to time).
Cheers
specific_ocean@hotmail.com
PostPosted: Tue Jul 16, 2002 7:40 pm
OK, here you go:
Sparkplugs gap at .035 (.30 is a typo I hope ; - )
Distributor Contact Points, gap at .020 which should give a dwell of 40-42º
Initial timing advance should be 6 to 8º BTDC but back-off if you hear "pings".
Valve Adjustment, Intake Lash at .010 and Exhaust at .020
(do a search for Valve Adjustment (all) and read-up on the process)
: I'm new to car fixology and would appreciate
: your help. I picked up all the stuff I need
: to do a tune-up (including a book which told
: me what to do). It also told me to either
: check a spec sheet at the place I buy my
: parts or call a garage.
: I tried both of those, and nobody seemed to be
: able to give me info (or just didn't want
: to). Where else can I find info on my car? I
: can't find the owner's manual. It's a 1966
: Coronet with a 225.
: I've got the correct plug gap of .30, but don't
: know the correct dwell, point gap, timing
: and - hmm, I'm pretty sure there was
: something else I need but don't remember. Is
: there somewhere online that has this info or
: might someone out there happen to have that
: info?
: I sure appreciate any help. As a side note,
: this past weekend I managed to pull,
: evaluate, clean and re-gap my own
: sparkplugs. I'm quite impressed with me. Up
: to this point, the only thing I've ever done
: is put gas in one hole and a key in another
: (and I'm sure I've even come close to mixing
: those up from time to time).
: Cheers
PostPosted: Wed Jul 17, 2002 8:30 am
Eep...nope not a typo. Guy at the parts counter told me the plug gap was .30 and even looked up in his computer what plugs I needed (which were pre-gapped to .30). S'okay. Pulling them all out again and re-gapping will be good for me.
Other than that, you lost me after the dwell, but that's s'okay too. It gives me more stuff to look up and learn about in my new car books!
Thanks so much for the info!
: OK, here you go: Sparkplugs gap at .035 (.30 is
: a typo I hope ; - )
: Distributor Contact Points, gap at .020 which
: should give a dwell of 40-42º
: Initial timing advance should be 6 to 8º BTDC
: but back-off if you hear "pings".
: Valve Adjustment, Intake Lash at .010 and
: Exhaust at .020
: (do a search for Valve Adjustment (all) and
: read-up on the process)
: DD
PostPosted: Wed Jul 17, 2002 10:50 am
: Eep...nope not a typo. Guy at the parts counter
: told me the plug gap was .30 and even looked
: up in his computer what plugs I needed
: (which were pre-gapped to .30). S'okay.
: Pulling them all out again and re-gapping
: will be good for me.
My guess is that you really gapped them at .030, machanic's "slang" would be: "Gap them at 30", meaning 30 thousands of one inch, written as .030
The "book" calls-out .035 gap which is what I would expect the pre-gap to be. .030 will be fine, a little tight but it will wear-in. .30 is just over a 1/4 inch, (.250) I don't think the plug would take that large of a gap.
: Other than that, you lost me after the dwell,
: but that's s'okay too. It gives me more
: stuff to look up and learn about in my new
: car books!
Keep asking questions, as they say, the only dumb question is the one that was never asked.
PostPosted: Thu Jul 18, 2002 9:52 am
I stand corrected indeed. .030 is the gap I used.
: My guess is that you really gapped them at
: .030, machanic's "slang" would be:
: thousands of one inch, written as .030
: The "book" calls-out .035 gap which
: is what I would expect the pre-gap to be.
: .030 will be fine, a little tight but it
: will wear-in. .30 is just over a 1/4 inch,
: (.250) I don't think the plug would take
: that large of a gap.
: Keep asking questions, as they say, the only
: dumb question is the one that was never
: asked.
: DD
Users browsing this forum: Bing [Bot] and 16 guests
