It is currently Mon Nov 17, 2025 8:14 am
 Post subject: lifter mystery
PostPosted: Wed Jul 17, 2002 4:58 pm
I have a 71 Dart with a later model Slant/6. The engine has twice now lost a cylinder and run on five. I take the valve cover off and one of the push rods is loose and the lifter is laying over on it's side. I'm guessing this is a faulty hydraulics issue. The lifter bleeds down or fails to pump up, colapses and the cylinder is dead......am I right? OR do I have some other problem? I'd like to install new lifter, pushrods and keep on driving. Any suggestions?
dodge47@att.net
 Post subject: Re: lifter mystery
PostPosted: Wed Jul 17, 2002 5:50 pm
: I have a 71 Dart with a later model Slant/6.
Unless you have a newer engine, the 71 should be a mechanical cam. We don't have too much info about your engine here, so I'm going to take some shots in the dark.
Have you checked this rod for straightness?
225/198 use one length rod, the 170 rod is shorter. Any chance in the world that during a rebuild you could have gotten one of the shorter rods mixed in?
Have you checked the rocker arm and the adjusting nut? Maybe you have a cracked rocker arm that is "openning up" of an adjuster that's backing out.
Have you done some serious milling on your head and/or block? If the geometry if messed-up, you may want to consider custom length push rods.
: like to install new lifter, pushrods and
: keep on driving.
I have a lifter and 225 pushrod in my extra NOS pile, so we could fix you up for minimal $$
tlg225ccr@aol.com
Users browsing this forum: Bing [Bot] and 20 guests
