It is currently Mon Nov 17, 2025 1:42 pm
PostPosted: Tue Sep 03, 2002 7:48 am
I am ready to finish machine the bore holes in my sl/6 torque plate. Any recommendations for the finish bore size?
lanctof@wsdot.wa.gov
PostPosted: Tue Sep 03, 2002 8:54 am
: I am ready to finish machine the bore holes in
: my sl/6 torque plate. Any recommendations
: for the finish bore size?
This really depends on what you will use the plate on.
For cast iron SL6 blocks, I would say 3.505 to 3.510 would give you over bore ability into the 3.5 range.
(most head gaskets have a 3.5 opening)
For the Alm. Block SL6 you need a 3.445 to 3.450 max plate, you just cant bore these engines as far and you need good contact around the tops of the cylinders.
Users browsing this forum: Google [Bot] and 24 guests
