It is currently Tue Nov 18, 2025 8:21 pm
PostPosted: Mon Sep 23, 2002 12:56 pm
I've got a 68 Dart w/ a 225 slant 6 w/ a one barrel holley and I want to switch to a 4barrel edelbrock w/ Clifford 4 barrel intake manifolds and I'm trying to find out how big of a carb and a cam I can put in her without blowin it.
thanks
matt
http://curbfeeler.com
matt@curbfeeler.com
PostPosted: Mon Sep 23, 2002 6:47 pm
Best suggestion I can make for a basically stock engine is the 1971-77 244 degree .406/.414 MP PN#3512639.
If you like Holleys, the 390 CFM 4 bbl is a sure bet. I've run them on 4 & 6 cyl engines. If you prefer the Carter, the 500 CFM is a little larger but also a good choice.
You can get 2 and 4 bbl adaptor plates for the Clifford intakes. You may want to consider a 2300 Holley/Webber 2 bbl for starters, and then step up to the 4 bbl later. I had one of these on my 74 Vega. It's a decent carb. Just a thought.
Later,
Gilly
tlg225ccr@aol.com
 Post subject: DOH!
PostPosted: Mon Sep 23, 2002 7:15 pm
I may have goofed on the "2300" model number on the Holley/Weber. Checked the Summit catalog, and that's what they list for the 500 CFM 2 bbl.
Sorry,
Gilly
tlg225ccr@aol.com
PostPosted: Mon Sep 23, 2002 10:13 pm
: I may have goofed on the "2300" model
: number on the Holley/Weber. Checked the
: Summit catalog, and that's what they list
: for the 500 CFM 2 bbl.
: Sorry,
: Gilly
The Holly 2300 comes in a 350 cfm version, I have run these on a slant and they work well once dial-in.
(I had to increase the pump shot and the power valve rating to get a lean transition into main feed "stumble" out of it)
PostPosted: Wed Sep 25, 2002 9:22 am
: The Holly 2300 comes in a 350 cfm version, I
: have run these on a slant and they work well
: once dial-in.
: (I had to increase the pump shot and the power
: valve rating to get a lean transition into
: main feed "stumble" out of it)
: DD
i had no idea that holley was now afilliated with holley. weird. i had a buddy who bought a weber DGEV progressive two barrel (from clifford) that was an awesome street carb. i ran a 350 holley on an m-1 intake and never cared too much for it. it ran ok but always seemed like it was too much for the street. the 390 four barrel always seemed a much better choice (only 40 more cfm thru 2 extra venturis.) 225 inch motor doesn't require much more air than that.
-james
ludite13@cs.com
PostPosted: Fri Oct 04, 2002 6:15 pm
: Best suggestion I can make for a basically
: stock engine is the 1971-77 244 degree
: .406/.414 MP PN#3512639.
: If you like Holleys, the 390 CFM 4 bbl is a
: sure bet. I've run them on 4 & 6 cyl
: engines. If you prefer the Carter, the 500
: CFM is a little larger but also a good
: choice.
: You can get 2 and 4 bbl adaptor plates for the
: Clifford intakes. You may want to consider a
: 2300 Holley/Webber 2 bbl for starters, and
: then step up to the 4 bbl later. I had one
: of these on my 74 Vega. It's a decent carb.
: Just a thought.
: Later,
: Gilly
We have a new product at Clifford Performance!!!
The Weber 44 IDF 530 CFM 2 brl. now has an adaptor for the Clifford Water Heated Intake Manifold. This has just come out of the Blueprint
Department with the new 08-1044 Carb adaptor and Weber 44 at $399.00 + Adaptor at $68.00. 909-303-2333
This will rip the Holley or the Edebrock because the 6 Cyl. engine needs more air than gas at higher RPM`S.
Thank you --Larry
larry@cliffordperformance.com
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 41 guests
