It is currently Wed Nov 19, 2025 11:11 pm
 Post subject: another carb question
PostPosted: Wed Oct 23, 2002 3:43 pm
Below is a description of a carburetor... I was wondering if this carb will bolt up to a slant intake? This is the description from the owner.
This is a one (1) barrel carburetor. It is a Carter Brand; I.D. Tag still attached with the following numbers: 7040S M 4 09 A. Number on side: 6W8. Other number on Carburetor is 2316 on side.
Thanks for any help!
PostPosted: Fri Oct 25, 2002 10:54 pm
: Below is a description of a carburetor... I was
: wondering if this carb will bolt up to a
: slant intake? This is the description from
: the owner.
: This is a one (1) barrel carburetor. It is a
: Carter Brand; I.D. Tag still attached with
: the following numbers: 7040S M 4 09 A.
: Number on side: 6W8. Other number on
: Carburetor is 2316 on side.
I do not recognize that number, do you have a PIC you can post? Most SL6 Carter 1bbls have "BBS" on the side.
Users browsing this forum: Ahrefs [Bot] and 4 guests
