It is currently Tue Nov 18, 2025 6:46 pm
 Post subject: Building fuel rail
PostPosted: Sun Oct 27, 2002 11:37 am
Has anyone posted a how to on this subject?
cybershark@taconic.net
 Post subject: Re: Building fuel rail
PostPosted: Sun Oct 27, 2002 4:31 pm
: Has anyone posted a how to on this subject?
You might want to check out the articles section.....I think Doc posted an article. I'm in work on a conversion, and am still digging up salvage yard parts, trying to build one by doing a cut/trim/fit/braze kind of thing. I'm also working on an article from a nuts & bolts perspective on the conversion.
I can tell you to stay away from Ford fuel rails, as all the nipples are "bent" at a slight angle on the rail, and won't work in straight line setup. The same goes for 3.0 V6 Mopar rails. I am, at this time, working on a Mopar 3.3 V6 fuel rail to see if it will work.
I have not had the opportunity to examine a Ford straight 6 rail, nor GM either. I'm trying to stay away from import rails, as most of them seem to be extruded aluminum, and I don't have the equipment to weld aluminum, nor the skills.
Roger
GTS225@aol.com
PostPosted: Sun Oct 27, 2002 6:49 pm
Here is a link to an excelent article, also site has other good tech articles.
<A HREF="http://www.sdsefi.com/techrail.htm">htt ... ail.htm</A>
flturbo6@aol.com
PostPosted: Sun Oct 27, 2002 8:18 pm
I think that if I were to attempt to build my own fuel rail that I'd look into the flexible hose mounting system sold by MSD ignition. Go to <A HREF="http://www.msdignition.com">www.msdignition.com</A> and type "fuel rail" in the search box. The flexible system is described under #4. This still isn't cheap, about $250 for a set of eight. Maybe you could get six for a little less.
Bob D
BBobbias@aol.com
PostPosted: Sun Oct 27, 2002 9:08 pm
There is some good information in Bob DiBiase's article at <A HREF="http://slantsix.org/articles/dibiase_ef ... ion.htm</A>.
Chuck
sl6@omnipages.com
Users browsing this forum: No registered users and 33 guests
