It is currently Tue Nov 18, 2025 11:00 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Sun Dec 08, 2002 7:32 am
Found a "correct" exhaust manfold in junk yard but it fell apart when unbolted. Might try to cut mine flat and change to the correct bolts ( has plane bolts ) Found supply for rebuild kit for the heat riser.. Will keep looking for now.
I have a 65 /6 what years manifolds fit?
Wild 1 AKA William Robertson
Owner Builder
65 Dart 270 2 door post /6 stock
89 dodge diplomat
66 Plymouth Barracuda
70 Challenger 451 ( Sold )
95 Chy New Yorker ( Stock )
PostPosted: Mon Dec 09, 2002 12:53 pm
Site Admin
Here is the way I have assembled the two manifolds:
1) Put the 3 manifold to manifold bolts in "snug" only.
2) Put the manifolds on the head WITHOUT a gasket.
3) Tighten the center intake manifold nut ONLY.
4) Tighten the 3 manifold to manifold bolts to full torque. The exhaust will "slide" up the head as you tighten the bolts.
5) Remove the manifold set and re-install with a gasket.
After step 4 you can check to see if there are any gaps between the manifolds and the head. I have never used any sealant using this method, but I have also not had to deal with badly warped manifolds.
One more thing to check is the clearance between the exhaust pipe and the block. I have seen the pipe so close to the block (sometimes touching) that the engine vibration will break the seal between manifolds. In this case you need to get the pipe re-welded before you tighten it up all the way.
Chuck Rivers, Webmaster
Image Image Image Image
 Post subject: Success, finally
PostPosted: Tue Dec 24, 2002 10:56 am
After the fifth try I finally have successfully installed my manifolds without any leaks! I used all the advice posted recently. I had to cut and rebend the choke stove link because I used a newer exhaust manifold with its choke with an older intake manifold (this is not mentioned in the newly posted article). I had to drill out my older intake manifold to accomodate the larger inboard manifold to manifold bolt. And most important of all I used copper based sealant, manifold to manifold and manifolds to gasket and exhaust manifold to exhaust pipe.. BTW the maifolds both checked out very straight with a straight edge but I still needed the sealer. I am so pleased to have the quiet back and no fumes in the car. I hope I don't have to do that again. Thanks for all the advice.
 Post subject: Way to Go!!
PostPosted: Tue Dec 24, 2002 11:04 am
Good work Jack,
You may want to re-torque everything after a few heat cycles, do the retorque while the engine is warm and be careful, just a light "snug down" to be sure nothing loosened-up.
 Post subject: Re: Success, finally
PostPosted: Tue Dec 24, 2002 3:46 pm
So what is the deal here I have a 65 /6 the exaust manifold from a later model with the early choke pull off, & it LEAKS, also the exhaust dampner spring is broken, so I was looking for a new exhaust manafold. I have aquired NOS a 65 choke pull off and & NOS Carter Carb.
Question do I need a 64 to 69 exhaust manifold to use the stock choke pull off I paid too much for, or can I use a later one, it looks like it will mount on later manifold. :?
here is the carb. it is listed as truck only but looks just like mine. http://cgi.ebay.com/ebaymotors/ws/eBayI ... 68038&rd=1
Here is the choke pull off or thermostat http://cgi.ebay.com/ebaymotors/ws/eBayI ... 1866237504
Thanks for any help and Happy Chirstmas :D
Owner Builder
89 dodge diplomat
Users browsing this forum: No registered users and 18 guests
