It is currently Tue Nov 18, 2025 1:48 pm
PostPosted: Sat Mar 22, 2008 8:57 am
For a photo hosting website, I've always liked photobucket - pretty much because it's insanely simple to use, and when you want to post pictures somewhere they have all the HTML or BBCode you need right beneath each picture. :) Just my .02..
<i>D'Artagnan</i>
<img src="http://img.photobucket.com/albums/v432/stephaniexchaos/dart/th_IMG_0326_zpsumhhfxi0.jpg">
PostPosted: Sun Mar 23, 2008 12:13 pm
Photobucket - simple.
PostPosted: Sun Mar 30, 2008 2:07 pm
If you have one or two melted places in the connector, you can move the wires to a good empty location. I have done this on 2 '66 Valiants when the alternator pass-thru connectors melted. There are about 6 unused places on this car. I was able to get replacement terminals at the local NAPA store. I had to ask for the connectors at the parts counter because they were not stocked in the store aisles.
To work on the "female" side of the bulkhead connector I pushed it back into the car, then angled it back through the hole into the engine compartment for easier access.
Chuck Rivers, Webmaster
Image Image Image Image
PostPosted: Sun Mar 30, 2008 3:51 pm
I found a NOS bulkhead disconnect, and changed out most of the brass connector under the hood and dash because of excessive corrosion. Additionally 60% of the conductors have been replaced under the hood, as well as several under the dash that were suspect, or had been hacked up by previous owners.
I don't want to be messing with this car weekly fixing electrical gremlins.
Check out my post on to read about the continuing saga of the lemon yellow Dart on the electrical board: Convertible Top Relay systems, and Electric Choke chatter.
PostPosted: Sat Jun 07, 2008 8:06 pm
Most of the connectors used on the older Mopars are Packard 56 series connectors. WayTekwire.com carries a small selection of the plastic shells, and a full line of the male and female terminals. These are the same style terminals used in the bulkhead connector. From what I have seen, they seem to have the best prices on the terminals. I usually just recycle some used shell from the pick and pull. They also carry a full line of the Packard Weatherpak connectors that are used on the modern GM cars. The Weatherpak products are a very nice design that is truely weather proof. Good luck with your projects
Scott.
PostPosted: Sun Jun 08, 2008 6:01 am
Thanks Scott,
I have finished the Dart wiring project excepting replacing the allusive turn signal switch. I have booked marked the site for future projects.
PostPosted: Sun Jun 08, 2008 6:45 am
Thanks Scott,
:oops: Workin' on it for ya.
PostPosted: Sun Jun 08, 2008 12:58 pm
OK, thanks Dan
PostPosted: Sun Jun 08, 2008 1:31 pm
Could we make a sticky or add something in the links section pointing folks to suppliers of the electrical parts used on these old cars?
Scott.
PostPosted: Sun Jun 08, 2008 4:45 pm
Scott.
Added it to the links.
Users browsing this forum: No registered users and 18 guests
