It is currently Wed Nov 19, 2025 3:07 am
 Post subject: What kind of times...
PostPosted: Thu Dec 19, 2002 3:27 pm
I just got my slant 3 months ago, I plan on do ing some braket racing.
What can i expect from my slant 4bbl offy intake 6 into 1 header and realy lumpy cam, I dont remember the dementions, somthing like 568 thanks
a cars' a car
but a mopars'
a roket
 Post subject: Do your homework...
PostPosted: Thu Dec 19, 2002 4:42 pm
It all comes down to a good combination of parts.
You need to get the actual specs on the cam, a real lumpy cam with a heavy car, tight converter, "tall" rear gear will be slow.
On the other hand, I have a 2700 lb car with a 3000 stall converter and 4.56 gears that runs low 14's, with a 170 SL6 :shock:
PostPosted: Fri Dec 20, 2002 6:17 am
the lift is .528 and duration is 284 i dont konw howmuch my cars' LBs but it is a 72 duster 455 rear gear
a cars' a car
but a mopars'
a roket
PostPosted: Fri Dec 20, 2002 1:53 pm
SSRN National Champion
I HAVE A 73 STOCK DUSTER WITH A OFFY INTAKE AND A HOLLY 4BBL AND RUN ON THE FRONT 2BBL WITH 4.62 GEARS EVERYTHING ELSE IS STOCK AND IT TURNED 10.61 IN 1/8TH LAST WEEKEND.
PostPosted: Fri Dec 20, 2002 9:51 pm
Sounds like it ought to at least run 12's in the quarter. :shock:
 Post subject: hey just went
PostPosted: Thu Dec 26, 2002 2:00 pm
hey just went after christmas hunting and in a old race shop i found a used 4bbl intake ill put it on tom whith a holly demond
a cars' a car
but a mopars'
a roket
