It is currently Thu Nov 20, 2025 3:52 am
 Post subject: Alum'm Slant buildup!!
PostPosted: Fri Jan 10, 2003 4:32 pm
Car Model: '23 T-bucket
Hey guys.....I picked up the March issue of Mopar Muscle, and they've got the first installment of a multi-part article on an aluminum block slant buildup. 8) The writer is claiming a 1hp/ci goal. I can't help but wonder if Doug has anything to do with this. :?:
Roger
 Post subject: Alm. SL6
PostPosted: Fri Jan 10, 2003 4:37 pm
You mean that those guys did not give me any credit :(
I drove down to LA and built that engine. :shock:
I need to go get a copy of this to see how the final article turned-out.
PostPosted: Fri Jan 10, 2003 4:48 pm
Well, don't get too antsy, Doc. The first installment consists of mostly a historical rundown and what to look for in the block. We'll have to wait for next month to see where it goes.
Roger
PostPosted: Sat Jan 11, 2003 5:33 am
Yea, this month was mostly history. It’s a pretty good write up of the Slant history.
Next month (or article) they are supposed to get into the buildup.
They did say that you can get the head gasket from www.slantsix.org
PostPosted: Sat Jan 11, 2003 9:14 pm
Was this engine build done using the BEST high quality parts for the job, or were corners cut to save a few bucks here and there? Nitrous?
PostPosted: Sat Jan 11, 2003 9:29 pm
The Aluminum build-up is the exact same combo of parts as the first HRM "Slantsixness" cast iron engine. The only difference being that the Alm. engine was bored to 3.440 (.040 o/s) but the iron block went out to .060 o/s. (3.460)
The head, manifold, carb, headders etc were all swapped over from the other engine. They want to see if the Alm. Block alone helps H.P. in any way. :roll:
PostPosted: Sun Jan 12, 2003 8:46 am
I can answer that question - NO. The aluminum block will save weight but will not make more power. With such things as the open deck design and thinner cylinder walls, I would rather have an iron block for a high power Slant buildup.
At the very least, I'd have improved the head work with bigger valves and more porting, and installed a better (Ultradyne) cam.
PostPosted: Mon Jan 13, 2003 8:15 am
I have been thinking lately of doing an aluminum motor for my road race car. If I could make the same power as my iron motor (say 250 at crank), but save 70 lbs, that would be worth a lot in handling on my already light car. Based on Wilford Day's experience and others, it seems the alum engine would be great up to 250-275 HP or so.
 Post subject: ??
PostPosted: Sun Jan 19, 2003 9:24 am
All I want to know is where do you buy the little superbird that goes between the #3 and #4 cylinder? ( Bottom picture of the headgaskets)
:lol: :lol: :lol:
Tom
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 3 guests
