It is currently Thu Nov 20, 2025 1:38 am
PostPosted: Sun Aug 17, 2008 8:07 pm
This is for a 1967 Barracuda upgraded to Electronic Ignition Also, I'm cheating a bit...it's got a 273, not a /6.
I know this is such a basic problem, but I'm kinda stumped. I've suspected that my battery wasm't charging, so I pulled off the NEG Cable while running & yup, the engine cut out. I've replaced just about all of the elec. components, so I'm not convinced the issue is parts-related, but who knows.
The simple answer would be 'a bad alternator'. But I just replaced this one, so I'm thinking a bad wire, or a wire connected incorrectly to say the Ballast Resistor (4 prong), or the wrong Ballast Resistor, Problem w/ the ECU, etc. Also, I have the older style, black-box Volt. Regulator - is this one OK w/ ECU?
I have hooked up an elec fan, fuel pump & a tachometer recently, but don't think these have any bearing on the alternator...or have I put too much load on this? I'd actually love to go to a newer style alt.
Any thoughts? I am not the best when it comes to electrical, so I'm relying on you smart guys out there.
PostPosted: Sun Aug 17, 2008 8:17 pm
Is your voltage reg. for a point ignition, or an electronic ignition? I am not the best with electrical, so just my .01 cent.
Also, is your alt new, or reman? I have read bad things about reman alts.
'74 Duster 225 Super Six w/904
14" Cragar SS wheels
PostPosted: Sun Aug 17, 2008 8:29 pm
Hiya man.
The Alt is a REMAN, so it could be the culprit. But I'm of the philosophy that if one goes bad, it might be the part. But if a 2nd goes bad, maybe there's an outside reason for 2 failures.
As for the Volt reulator, I dunno, it was a Points-Type Ignition & the VR did stay as it was pre-ECU.
Note: I also have an ECU upgrade on my D100 w/ the same VR from the points-ignition days. On the D100, I have no charging problems.
That's one reason I am suspecting wiring - I am also considering the wiring block @ the firewall. I did have to by-pass this for my ignition switch (thick, red wire w/ fusible link).
PostPosted: Mon Aug 18, 2008 1:06 am
PostPosted: Mon Aug 18, 2008 3:18 pm
I had a wireing problem with my car not to long ago, and SL6 Dan told me "dont throw parts at the problem, buy a factory manual for your car, and diagnose the problem." So I did, and alls fine now!
PostPosted: Mon Aug 18, 2008 6:53 pm
65Dodge100,
Thanks for the links, they are extremely relevant to anyone dealing w/ the elec system.
I did a lot of what was discussed in the mini-artlicle/thesis by SlantSixDan
(Thanks too, Dan) & am coming to the conclusion that my 'lifetime' guaranteed alternator is turning out to be what you guys have been saying - half-assism in the remanufacturing.
I have determined that my Advance Auto alternator is bad by doing a swap w/ my 68 D100. I put the D100s alternator in the BCuda & the following occurred: Enigne dies @ speeds below +/-1750RPM.
My uncientific testing also seems to indicate that my D100s alternator might be on the way out as well.
Regarding other components, I did similar swap-out trial & errors w/ the following: 1) Volt reg - Both get voltage, but noticed that the D100 reads 0.1 volts, while the BCuda's VR read 10.3volts. Maybe I chaecked wrong
or maybe this indicates something?
2) Wiring seems to be OK, but i replaced the green wire from Alt' FLD' to VR 'FLD',
3) Ignition switch - Swapped w/ D100 & no change, however on the BCuda, there is no wire to the 'GRD' prong on the BCuda, but there is on the D100 - either way, it doesn't seem to matter to strating & charging. The wiring diagram seems to show this wiring goes to the instrument panel.
4) Ballast resistor - I'm still not sure about the difference in the BR, but this seems to function correctly.
5) ECU - no issues.
As i need an alternator & I want to improve charging, esp @ idle/low speeds, plus provide more power for any multitude of accessories thaty might come along, I think I'd like to consider doing one of those upgrades to the newer alternator, the Nippondenso, I think.
Any ideas on this ramble?
PostPosted: Mon Aug 18, 2008 7:40 pm
Any thoughts on that topic?
PostPosted: Mon Aug 18, 2008 7:51 pm
What is your ammeter doing? Does it show a charge at start, and return to zero? Is it maxed out at idle? Or is it bouncing all over the place?
Also, a VR only reading 10.3 volts? I think its time for a new one. Be careful though, the last one I had almost fried my batt. My new one I got from O'Reillys. I don't think it should read more than 13v, and no less than 12v at idle, but don't quote me on that, someone better my be able to help you more.
 Post subject: ...and another thought.
PostPosted: Mon Aug 18, 2008 8:12 pm
Could the fact that I have a pretty 'lopey' cam in the engine be causing charging deficiencies @ idle?
PostPosted: Mon Aug 18, 2008 8:25 pm
I don't think so, not unless it runs like total crap and barely idles.
But again, I am no expert.
Does it idle smooth?
PostPosted: Mon Aug 18, 2008 10:06 pm
PostPosted: Mon Aug 18, 2008 10:12 pm
Go see my latest post in the "Slanted Network" section of the board, about Old Car Parts Northwest. He's got a giant tub full of brand-new Chrysler alternators.
Both of these are odd readings...
PostPosted: Tue Aug 19, 2008 6:37 am
Here's something most guys won't admit: Perhaps it's because I dunno what the heyll I'm doing.
Anybody got any thoughts about the culprit being the alternator? If so, I'll
send Old Car Parts Northwest a line, or look up someone local.
In the meantime, I'll check out some of ya'lls threads regarding upgrading to later model alterantors....hmmm, my Bro-in-Law did give me an alt out of a 1988 ramcharger a few years back. Is that a suitable Alt to use? It's got 2 'FLDs' & the rear has 3 square openings & is a bit thicker in profile than my original styled alternator.
 Post subject: aLTERNATOR P/Ns
PostPosted: Tue Aug 19, 2008 9:51 am
On my 2 Alternators, I've got the following numbers 'embossed' (reverse of stamped):
1) 1967 -69? Alternator = #2095192
2) 1988? Alternator - 2095191
Are these actually Parts Numbers or are they casting, mfr or other non-relevant numbers?
Thanks again for tolerating my questions.
PostPosted: Tue Aug 19, 2008 9:59 am
Not alternator part numbers...they're really old electrical part numbers for some component of the alternator. Where do you see them?
