It is currently Wed Nov 19, 2025 8:43 pm
PostPosted: Tue Aug 26, 2008 10:29 pm
Hey guys yet another conundrum for you guys. My fuse box on my 74 swingers is well lets just say swinging in the air. The problem is that mounting bracket that is supposed to be there is not DANG :x . I am open to suggestion on how to go about fabricating a new bracket to hang my fuse box on. THOR/Bobby and I have thought about getting some sheet metal making the bracket and then coating it in plastic to prevent grounding. Again I turn to the eternal wisdom of this form to find a way out of this problem.
Thank you,
Chris
PostPosted: Tue Aug 26, 2008 11:02 pm
The original bracket was simply a sheet metal tab on the lower dash. The fuse block was retained by a big Phillips head screw that went through the tab into the fuse block. The body of the fuse block is an insulator so no grounding or shorts occur. I find it quite odd that the mounting tab is missing. If it's truly missing.
PostPosted: Tue Aug 26, 2008 11:51 pm
Well I did not approach it from that angle well let me take a look in the morning and I will get back to you on that.
Thank you,
Chris
PostPosted: Fri Aug 29, 2008 1:04 pm
Chris,
The plastic fuse box has a slot on the back about 1 1/4 inches wide. Get a light and get down in the driver's side floorboard on your back and look up into the dash on the left side of the steering wheel just above the emergency brake. About four or five inches from the bottom of the dash (you should see a ground wire and screw at the bottom of the dash) is the tab for mounting the fuse box. It actually points up toward the ceiling of the car. Put the slot on the back of the fuse box on the top of the tab and slide it back down towards your face. It should slide on and off easily.
From what I remember that tab does not come off. Hope this helps.
PostPosted: Fri Aug 29, 2008 2:24 pm
D'oh! That's right. I forgot the later models slip onto the mounting tab. I was thinking of my '66 Dart that used a screw to retain the fuse block.
 Post subject: Yep...
PostPosted: Fri Aug 29, 2008 6:21 pm
It's funny my '67 has the 'screw, and the '73-76's had the tab... sure makes it easy when you want to drop the box and change a fuse...
-D.idiot
Of course hanging upside-down to look over the fuses under the dash, like a bat, kind of is fun, too...
PostPosted: Fri Aug 29, 2008 10:40 pm
Ok after taking a look and feeling vary light headed I figured out where the fuse box goes thank you for that. But there is still one thing that is confusing me. There is a small cylindrical component that is still hanging down. I would take a picture of it but I don't have access to a digital camera. The only thing that I can tell you guys about it is that on it I could make out Little Fuse, 12 volt, DOT Flasher. Now I'm new to all of this and any help would help sorry I cant get a pic yet if needed I can try and get it by tuesday.
Thank you,
Chris
PostPosted: Sat Aug 30, 2008 5:22 am
That would be the flasher for either the turn signals or the 4-way emergency signal. There should be a spring clip somewhere under the dash to hold it.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Aug 30, 2008 9:48 am
Ok well it looks like I have some more investigating to do under my dash. Thank you guys for all of the input I really appreciate it. Well for now I AM BAT MAN!!! (As I hang upside down under dash).
Thank you,
Chris
PostPosted: Sat Aug 30, 2008 9:57 am
It's possible the clip could be missing too. I don't know exactly where to tell you to look but it obviously will be in reach of the leads to which the flasher is attached.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
