It is currently Wed Nov 19, 2025 3:24 am
PostPosted: Fri Jan 31, 2003 6:43 pm
:? I have an oil pressure gauge, and the oil pump has large threads at the end of the oil pump.
The sender I was sold for the gauge set up has smaller threads. I think there must be a sender for a gauge with large threads, but the auto parts store says its for a idiot light setup.
Does anyone know if there is a sender with larger threads for the gauge?
Bob Brady
Slanted 67 Barracuda
 Post subject: one for the bush
PostPosted: Sat Feb 01, 2003 12:59 am
Can't you just use a brass thread-reducing bushing?
'66 Cuda 225/4spd
'64 Dart GT 340/4spd
PostPosted: Sat Feb 01, 2003 5:31 am
Yep, just go to Ace Hardware and spend .75 for a pipe reducer.:D
PostPosted: Sat Feb 01, 2003 5:48 am
I've had better luck at Ace Hardware stores finding special fasteners, fittings, etc. for an automotive project than any of the auto parts stores.
Ace Is The Place.
Cecil
PostPosted: Sat Feb 01, 2003 8:33 am
The factory had to use an adaptor fitting to get the gauge type oil pressure sender onto the SL6, it is a special brass fitting because it has an angled tapped hole, this keeps the large "can" on the gauge type sender from hitting the block.
Many times I move this sender to a different place, like to the rear of the main oil gallery. (there is a casting "boss" there, some are already drilled and tapped)
If the new location is not an option, get a fitting that has a 45 degree bend in it, this will give you the clearance. You will need two brass fittings if you don't have the factory one, the first will be a 1/2 to 1/8 (?) reducer, then a 1/8 (?) to 1/8 45 (or 90) degree bend. ( the ? is because you can use other sizes as long as it starts as 1/2 NPT male and ends-up at 1/8 NPT female thread at the end. (with at least 20 degree of bend along the way)
PostPosted: Sat Feb 01, 2003 9:19 am
Thank you for the feedback. I would never have thunk I was missing the adapter.
I can make it work. :o :lol: :D
Bob Brady
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 11 guests
