It is currently Wed Nov 19, 2025 1:23 am
PostPosted: Tue Feb 11, 2003 10:35 am
Howdy,
Is there any problems with swapping a /6 from an auto to a stick? I've got a 1962 Valiant wagon stick with a dead engine. And I've got an engine sitting around from a 68/69 Dart. Only the Dart engine is hooked up to an 904. Is it just a straight swap?
I was thinking there was something about changing flywheels, but I can't remember.
--Dave
 Post subject: 68 SL6 Engine in a 62
PostPosted: Tue Feb 11, 2003 11:29 am
To get the "later" 68 engine into the 62 you will need to use the 62's oil pan and pick-up tube and you will need the larger hole flywheel.
Your 62 should have the gear reduction starter, if it does not (60 & 61 had a direct drive starter) then you will need the more common gear reduction starter to go with that 68 and newer flywheel.
Users browsing this forum: Bing [Bot] and 16 guests
