It is currently Thu Nov 20, 2025 12:24 am
 Post subject: No start
PostPosted: Mon Nov 03, 2008 6:18 pm
I put a holley 350 cfm two barrel on my car and I disconnected all the one barrel choke but now I have no power to start my car. I was wondering if there is a ground that might was connected to the old choke that would affect this. I dont know what else it would be.
Ronnie
http://www.cardomain.com/ride/2714941
PostPosted: Sat Nov 08, 2008 8:37 am
Should I ground the old connectors for the choke?
Ronnie
PostPosted: Sat Nov 08, 2008 9:30 am
no.
you may have bumped something, check the usual suspects like battery clamps/cables/firewall connector/fusible link. your starter may also have decided now would be the time to crap out, check the relay (follow the small starter wire back to a metal box and check connections) and in park, short the small terminal on the starter to the large one and see if it turns over.
PostPosted: Sat Nov 08, 2008 2:01 pm
I just replaced the starter relay, but I still tried that an no go.
Ronnie
PostPosted: Sat Nov 08, 2008 2:27 pm
what is your multimeter telling you?
PostPosted: Sat Nov 22, 2008 11:24 am
Sorry for the long wait. I got it to turn over finally. I think the ingnition switch is out.
Ronnie
