It is currently Wed Nov 19, 2025 3:22 am
 Post subject: Surging problems
PostPosted: Fri Nov 21, 2008 11:05 am
On my 81 dodge D150 truck when i have the headlights on they sometimes get bright then go dim and if i have the blower fan on it will increase the speed and then die down. They both do it at the same time. Also when the lights are on i dont have any low beams. I replaced the bulbs awhile ago and when i bought the truck the guy changed the dimmer switch to. I tested the switch and it works according to my voltage meter. I checked the wires and there is no shorts. So i was wondering if any one here knew what the problem is. :?:
Joe Reusch
1981 Dodge D-150 Slant Sickness
PostPosted: Fri Nov 21, 2008 2:20 pm
Car Model: 87 B150, 1970 Valiant 4-door
voltage regulator?
PostPosted: Fri Nov 21, 2008 2:32 pm
Yep, the surging voltage is likely a problem with the voltage regulator and/or alternator. The headlight problem is likely a faulty (open) connection between the high/low beam switch and the wiring harness, or in the low beam feed wire between the high/low beam switch and the headlights. You really need factory wiring diagrams to chase down faults like this; recommend you buy a factory service manual as soon as you can.
 Post subject: reply
PostPosted: Sun Nov 23, 2008 12:05 pm
When the lights are on they work fine with the high beams but as soon as you click the dimmer switch they just shut off. So i dont know if that would be an open circut. They worked fine until one day tehleft side just didnt come on one day so i replaced both of them and it never had lows since then.
Joe Reusch
PostPosted: Sun Nov 23, 2008 12:30 pm
Possible a bad ground or corroded terminals. Have you tried cleaning all connectors and grounds?
 Post subject: Re: reply
PostPosted: Sun Nov 23, 2008 2:04 pm
Yes, it would be an open circuit somewhere between the dimmer switch and the low beam filaments, as I said. Go check it out.
It's not bad grounds; if it were that, the high beams wouldn't work. The low and high beams have a common ground path, but separate feed paths.
