It is currently Wed Nov 19, 2025 3:23 am
 Post subject: ignition-on 12v source
PostPosted: Sun Nov 23, 2008 12:07 pm
I have a 81 D150 , what would be a good ignition-on 12v source in the engine bay for my HEI relay ? It will be on the passenger side beside my radiator. I still have all of my lean burn wiring still intact.
Thanks
Dave
81 Dodge D150
It looked easier in the book .
PostPosted: Sun Nov 23, 2008 12:41 pm
One of the blue wires comging off of the alternator (trace it to the choke).
PostPosted: Sun Nov 23, 2008 12:56 pm
Thanks Reed
I'll check on that later, would that be the same wire that is plugged in ,were the choke is also plugged into.
Dave
81 Dodge D150
PostPosted: Sun Nov 23, 2008 1:14 pm
The alternator has the big cable that is secured by a nut and two smaller wires that attach with spade connectors. The big cable with the nut is the (+) battery feed. you don't want that one. You want to tap into one of the wires that attaches with a spade terminal. Alternatively, you can splice into the wire that feeds the choke.
PostPosted: Sun Nov 23, 2008 1:42 pm
I got it , those two wires are attached to the brushes.
81 Dodge D150
PostPosted: Sun Nov 23, 2008 1:43 pm
I would use the original coil + otherwise it might not have power during cranking.
PostPosted: Sun Nov 23, 2008 2:00 pm
Joshie225,
That is what I was thinking about first , but I was not sure if it would work with the relay.
81 Dodge D150
PostPosted: Sun Nov 23, 2008 2:02 pm
Just picking either of the alternator field wires at random is definitely not a good choice for a +12v source with ignition key on. You don't want to interfere with voltage regulation. Better to go to the ballast resistor on the firewall, unplug both connectors from it, figure out which connector has +12v with the ignition key in the "on" position, and use that. Since you'll be bypassing the ballast resistor to install the HEI, you can also just use the original coil + wire as Josh suggests.
PostPosted: Sun Nov 23, 2008 2:06 pm
Dan,
I do not think I have a ballast resistor , but I think I will use the original coil + wire.
It is starting to come around , hopefully after the first of the year it will be on the road.
Dave
81 Dodge D150
