It is currently Tue Nov 18, 2025 12:40 am
PostPosted: Tue Mar 11, 2003 4:08 pm
This baby here is about to undergo a slight transfermation, here's my plan:
Clifford 4bbl maninfold
edelbrock 500 cfm carb
lokar throttle and kick down cables
Custon ground cam from a company called SLR 498 lift 290 duration at 1.5 rocker ratio
forged crank cut .20/.20
1.7 1.44 SI valves
ported head and polished on exuast only
66' block
KB 2.2l turbo pistons 1.5mm oversized (3.504 total bore)
Comp valve springs, locks, and retainers
comp pushrods
double timing chain from cox bros.
198 connecting rods
Total seal piston rings
3100rpm custom stall converter from edge racing converters
mopar 6x1 header ceramic coated
MSD6a ignition
fel-pro gaskets
8 3/4 rear end with 3.55 gears
So far it has been fun tearing down the engine and getting it ready, I just need to collect all the parts now and that mean $$$$.
My goal is to be done with this motor in less than a year so I can start racing. As for the 1/4 mile, I would love to get into the 15's at first and then work my way up from there. I guess we'll just have to wait and see.
73' Duster 225
<img src="http://longrod.moparpages.com/enginedone.JPG" width=200>
PostPosted: Tue Mar 11, 2003 4:09 pm
Here is one of my new toys
I've been looking for a set of 198 rods since september and I finally got em
Pistons are next...I'm chipping away at it
73' Duster 225
PostPosted: Tue Mar 11, 2003 7:46 pm
That's pretty close to the same combination I have in my moder. With 3.55 gears it's gone 14:80@90 in my '66 Valiant street car.:)
PostPosted: Fri May 09, 2003 12:24 am
Got my .60 over KB268 pistons today for my birthday, now I'm saving up for the machine work.
73' Duster 225
PostPosted: Thu Aug 21, 2003 11:41 am
Got the paint prep work 90% done, soon she'll be sublime :twisted:.
Motor pull went off without a hitch, now I just need my machinist to finish the block.
More updates soon, she would be done a little quicker but I payed for two albacore fishing trips in September and that stuff is'nt cheap.
PostPosted: Mon Sep 29, 2003 9:37 pm
Making a little progress. Block got back from the machine shop, just need to get a few more pieces.
73' Duster 225
PostPosted: Fri Jul 02, 2004 3:34 pm
I have been working hard. Almost time to go to the track.
73' Duster 225
PostPosted: Wed Feb 16, 2005 7:47 pm
Now all I have to do is take it to the track. Oh and I still need to swap in my 8 3/4 rearend.
