It is currently Wed Nov 19, 2025 3:22 am
 Post subject: right side turn signal
PostPosted: Mon Jan 19, 2009 8:17 am
Quick question.... right side turn signal (72 duster) stays lit up when switch is turned on ( lites include, fender, front,rear) rear is 1/2 intensity....
ground problem? bulb problem? flasher? turn switch in steering?
everything else works as designed.
PostPosted: Mon Jan 19, 2009 9:56 am
Dim bulb most often = bad ground.
PostPosted: Mon Jan 19, 2009 6:40 pm
thanks
