It is currently Wed Nov 19, 2025 2:19 am
PostPosted: Mon May 12, 2003 10:04 am
I could use some advise with this question
I just bought a 67 Dart GT convertible and it has the standard 13" steel wheels with full hubcaps. I would like to install the rallye wheels that you see on the later 68 or 69 darts and dusters.
I would like to stay with the 13" wheels if possible, but did they ever make these? Maybe on a barracuda or ??
If not and I have to do the 14" conversion, what do I have to go through to keep the speedometer correct. Is this just a gear or major parts?
Thanks for your time with this.
Matt Guesto
(225 slant Six)
"225 Slant 6"
Super 6 and 2.25" exhaust.
PostPosted: Mon May 12, 2003 10:34 am
Matt,
13" rallyes do not exist, but you are better off with 14s anyway - better handling and braking. You can either just use tires with the same outside diameter as your 13s (like some 225/60-14s or 195/70-14s), or you can get a different speedo gear - easy to get and change. Any restoration or performance Mopar shop can get gears for you for about $15 (like www.manciniracing.com or www.kollerdodgeparts.com).
Welcome to the site!
PostPosted: Mon May 12, 2003 10:39 am
The only 13 wheels i'm familar with are some cragers that were factory to a re-bagged 65 dart (charger package all with 273s) extremly rare is being mild to describe these wheels. Agree with 270 get some 14s.
