It is currently Tue Nov 18, 2025 11:08 am
 Post subject: Not idle on holley 1920
PostPosted: Fri Dec 25, 2009 2:37 pm
Hi guys, merry christmas for alls! Not idle on holley 1920, but if i close the idle air bleed the idle comeback. This problem is not permanent.
Aspen 79 Holley 1920 HEI
Aspen 80 Super Six
PostPosted: Fri Dec 25, 2009 2:51 pm
Carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted here for free download.
PostPosted: Fri Dec 25, 2009 3:06 pm
Thanks Dan. The carburetor was a rebuild, but the idle system not working. This carburetor it´s very easy to rebuild, i dont understand the problem. The problem is not permanent and the main metering system works very well..
Aspen 80 Super Six
PostPosted: Fri Dec 25, 2009 4:32 pm
Any idea, please
Aspen 80 Super Six
PostPosted: Fri Dec 25, 2009 5:01 pm
Transient problems like this suggest there's dirt or corrosion in some of the very small idle passages in your carb. You may want to try using a spray can of carburetor cleaner to backflush the two idle air bleeds (one small and one tiny) that face the sky; you can see them on the front wall of the carb throat once you remove the air cleaner.
PostPosted: Sat Dec 26, 2009 6:37 am
Thanks Dan. The idle system has a idle well (i saw in the pdf and in the carburetor) and in my carburetor he moves to top and bottom. is normal ?? Sorry for my inglish
Aspen 80 Super Six
PostPosted: Sat Dec 26, 2009 8:31 am
I'm not sure what part you mean by "idle well". Can you show us in one of the pictures?
PostPosted: Sat Dec 26, 2009 8:38 am
Dan the part is a brass tube on the galosine pass to the main jet to idle system.
Aspen 80 Super Six
PostPosted: Sat Dec 26, 2009 9:38 am
SL6 CHILE,
On page 13 of the 1920 manual, figure 6 shows a picture of the idle well. You can pull the screws holding the economizer body (see figure 8a) in place and clean out the passage way with a piece of 10 to 12 pound nylon fishing line and blow it out with carb cleaner. If that doesn't work and you hit a some blockage use a guitar string. That should clear up your problem.
PostPosted: Sat Dec 26, 2009 10:29 am
That brass tube should not move. It should be solidly fixed in place.
PostPosted: Sat Dec 26, 2009 10:53 am
Hi guys, good news! I clean the economizer body and the slant works perfect. Thanks for your help. Greetings from Chile
Aspen 80 Super Six
Users browsing this forum: Ahrefs [Bot] and 14 guests
